ODSS Bolters return from
WINCHESTER
Virginia
September 21-23
Read the
HOT WASH!
17 members (78buckshot, cmayna, 2-Ton, D'Ecosse, David Bush, AS37, 2 invisible),
155
robots. |
Key:
Admin,
Mod
Forums65
Topics123,390
Posts998,842
Members47,294
Most Online1,229 Jan 21st, 2020
OP
Son has a 54 DRW 3800. Also a SRW 3600 chassis with new brakes all the way around. Wheels I have clear the 3600 rear end but not the 3800 (late model 16ā GM). Can I simply swap backing plates, hardware, drums, etc? Your guidance is appreciated!
Are you planning on doing real truck stuff, or building a Cowboy Cadillac? There's a reason a 1 ton has bigger brakes than a 3/4 ton. Jerry
OP
How about half way in between. Not enough to need 1 ton brakes.If I wanted a cowboy Cadillac Iād put a disc brake swap and an LS in it.
