The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
Since we put up promos last two weeks, we have had a bunch of activity in
The Side Lot.
See what's happening with a Stovebolt Collective near you
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: too many to list!
THE SIDE LOT.
Go see!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 members (59 fleet, Gdads51, Flatblu4748, Fox, glenns towing, dougs), 114 guests, and 4 robots.
Forums60
Topics129,204
Posts1,047,808
Members46,221
Most Online1,229
Jan 21st, 2020
#1442748 Sat Feb 26 2022 03:28 PM
Good morning boys and girls, I have a '51 3800 Panel with a 350/T5. Runs fabulous. My problem is shutting it off. The motor will continue for 3 seconds after I turn off the key. It's not "Dieseling". Any suggestions?
Thanks in advance.
Ed Lupardo
Ed Lupardo #1442749 Sat Feb 26 2022 03:47 PM
Leo Offline
Ed, I would suggest posting this in the engine shop. A 350 engine doesn't really relate to a 1951 panel, likely more people will see your post.
Ed Lupardo #1442753 Sat Feb 26 2022 04:51 PM
Does the truck have an electric fan? If so it will provide current till fan motor dies down. A diode or switched relay will solve.
Evan
Ed Lupardo #1442759 Sat Feb 26 2022 07:20 PM
Sir Searchalot
I will assume with your self diagnosis that you do not have a carburetor? That is the only way you could say it's not dieseling.
Before we get the necessary info/history/back story and motor accessories, the first answers will be dieseling or too high of an idle....or a fancy "hot" spark plug. There are other heat related causes. Lean/rich/carbon/plugs/heat riser/exhaust leaks/timing.....also a bad ignition switch or wire or a miswire.
1. Is this a new motor install? or rebuild?
2. Does it have headers? Do they leak?
3. Been running ok until just recently this started happening?
4. Have you just completed any motor work/replacement of any parts. Done any timing?
5. Carburetor? Carburetor model? Hot rod motor parts?
6. Any wiring done recently?
7. Spark plug part number? Stock coil?
8. Mileage on motor?
9. Happens after short runs and long runs? If you start it up cold and run for two minutes, does it still run on?
Ed Lupardo #1442791 Sun Feb 27 2022 02:04 AM
A Lot more information is needed to come up with an idea. What are you using for ignition? Points/condensor/coil? HEI? Aftermarket stuff like MSD?
1949 Chevy 3600
1975 W-25 Hurst Olds
1991 Chevy Silverado
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
I'm a GM man!
Ed Lupardo #1442796 Sun Feb 27 2022 02:46 AM
Timing too far advanced for the octane rating of the fuel you're using?
1939 Packard Standard Eight Coupe
1950 Chevrolet 3100
1956 Cadillac Coupe de Ville
1966 Oldsmobile Toronado
1966 Ford Mustang
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150
1995 Ford F-150
Ed Lupardo #1442816 Sun Feb 27 2022 02:12 PM
Carburetion specialist
Shut it off 3 seconds before you are ready to shut it off???? wink
Sorry, could not resist.
Jon
The most expensive carburetor is the wrong one you attempt to modify
If you truly believe "one size fits all" try walking a mile in your spouse's shoes!
[image]http://www.thecarburetorshop.com/Avatar.jpg[/image]
carbking #1442860 Sun Feb 27 2022 07:16 PM
Sir Searchalot
Jon
Very good Jon grin Now that you say that, it dawned on me that 3 seconds could be really close to normal to stop the rotating mass after the last plug fires and sends a power stroke. (Momentum).
Ed Lupardo #1442909 Mon Feb 28 2022 01:16 AM
This sounds like a feedback from the alternator. Try running on just the battery with all the wiring disconnected from the charging system and see if the run-on happens.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
