The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (JW51, porsche, TPR57C, Mike Burns), 97 guests, and 3 robots.
Forums59
Topics128,612
Posts1,041,915
Members46,061
Most Online1,229
Jan 21st, 2020
If you have properly working choke and throttle cables, do you need the choke rod on a Carter YF 2100S? What function does it perform?
Thanks!!
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
29 Years of Daily Driving. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
I would say, yes. It serves to crack open the throttle blade as you pull the choke closed. This allows the engine to keep running and not be completely "Choked" out. Also, why would the engineers put it there if it wasn't necessary? So, instead of pulling the choke and then the throttle, you just have to pull one of those.
58' 3200 235 3-speed/OD
A vehicle with a manual choke also needs acetylene headlights, a hand crank, and clincher rims on wood spoke wheels.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
Jerry, you forgot the hole in the floorboards for propulsion. wink
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Carburetion specialist
Jerry - it could be argued that someone needing an automatic choke on their vehicle might also need a chauffeur wink
As far as the hand crank is concerned; 45 years ago I had one. Wish I had a digital camera then, as the looks I got in the parking lot were worth the effort to crank the engine (it would start on the first half revolution as long as the manual choke was set wink ) It also had an electric start, but the hand-crank was a lot more fun!
Don't remember acetylene headlights; I did use carbide lanterns when I was a youngster.
KLhansen - you wouldn't have to worry about the holes in the floorboards if you lived in Missouri. MoDot would see to these with all of the salt which they dump on the roads for the folks needing the automatic choke, the automatic transmission, and above all, a chauffeur in the winter frown
OP - absolutely required, no; but I would leave it, unless there is a specific reason not to use it.
Jon
The most expensive carburetor is the wrong one you attempt to modify
If you truly believe "one size fits all" try walking a mile in your spouse's shoes!
[image]http://www.thecarburetorshop.com/Avatar.jpg[/image]
Wally /Montana It amazes me how the whole stovebolt tribe battles those liquid fuel carburetors,fuel pumps,dirty tanks,filters and lines. Oh and the heat riser wore out system always stuck and leaking. A few brand new fork lift parts will bypass all of that so you don't wash your cylinders down every morning with gasoline.My 51 6400 starts with just a bump,is then immediately ready to go smooth out the driveway.Also the fuel is 1/2 the price,no sludge,oil stays bright ! If you tear it down don't have to use some sludge cutting coal oil flush is already clean !!
ApacheFiend I never saw a choke that worked properly,they all wash your cylinders down,same way with points distributors just busy wearing down. Thankfully the Delco engineers developed HEI and Delcotron modern systems !!
You mean that choke rod does something that I used to do myself with the throttle on my Monojet? Some day the driver will have no function at all. Wait......
