Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
1 members (Hotrod Lincoln), 49 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,565
Members47,279
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
Stovebolt Photo Moderator
Thanks Pal...........IF it's Gerry's it's swiss cheese
1947 - 3800 dually known as "Deadwrench"
Link to a few photos [photos.google.com]
In this world there are givers and takers. The takers eat well, the givers sleep well.
Billy - I kind of remember you had one. Never knew you had a condensation problem. It's all about psychrometrics. IF the surface temperature of anything is below the dewpoint of the air that surrounds it - bam - condensation. Someone mentioned a dehumidifier which does the moisture removal by passing the air over a coil and wringing out the moisture as the coil is below dew point. They work well.
I like the idea of finding an old travel trailer or enclosed trailer that may not be road worthy, but worthy enough to winch onto my gooseneck. I have been watching construction jobs come to an end around here and asked the supervisors what are the plans for the small office trailers ? They tell me most of them are leased and go back to the owners.
My gem is out there. I just need to be at the right time / right place.
Unrepentant VW Lover
Joe -- You need to go to more equipment auctions. You may be on a better plan with an old office trailer rather than a sea container, anyway. Even the twenty footers are really heavy. If you remember the Landoll trailer I had at Winchester? Did you notice the big Braden winch on it? That trailer was specifically set up for moving sea containers (20-footers as well as 40 footers). They are not trivial, even when empty, and require a hefty winch (and cable!).
What about an enclosed car hauler trailer? Even new, they are not horrifically expensive (by the time you get done writing cheques, it's probably close to a wash between a sea container, winch and whatever else you need, and just getting a new enclosed trailer). Putting a Maine tag on it is pretty reasonable, too.
And I can corroborate Brother Marlow's condensation claims. I had issues in my container, too (and mine even had a hole in the door caused by someone stabbing it with a forklift). I just left the door ajar and the problem went away.
"If there are no dogs in Heaven, then when I die I want to go where they went."
Will Rogers
1927 Chevrolet Capitol 1-Ton Express -- A work in progress
In Project Journals
1949 Chevrolet 3804
In Gallery Forum
1973 IH 1310 Dump
2014 Ford E-350 4x4 (Quigley)
In Daily Driver Gallery
Page 2 of 2 1 2
Moderated by  Bill Marlow, SWEET
