The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Chuck52, 3B, Bruce36 1.5, GMCJammer51, Bill Hanlon, Bill Trotter), 98 guests, and 3 robots.
Forums59
Topics128,612
Posts1,041,927
Members46,061
Most Online1,229
Jan 21st, 2020
#1440260 Sun Feb 06 2022 07:45 PM
lost the inner wheel bearing on last trip and trying to find replacements NAPA says they might have the outer bearing and race but not the inner as well as the seal type thing does anyone know a source the inner bearing is Hyatt 8-98 and the outer is Hyatt A131224 as well as the seal piece?
hippydave #1440319 Mon Feb 07 2022 03:17 AM
3B Online
Hy hippydave, the whole part number for the inner bearing is C125298WA GM 7450335 they cross to two pieces SKF BR25883 $41.89 BR25519 $19.14 at RockAuto. The outer bearing number I find is A131224Z GM 7450336 they cross to two pieces SKF15103S $14.56, Timken 15243 $6.63 at RockAuto The seal crosses to National 6785 $21.79 at RockAuto seal dimensions are O.D. 5 1/8" I.D.4.00" Thickness 1/2", hope that helps.
hippydave #1440325 Mon Feb 07 2022 03:32 AM
My parts book list 1958-59 Series 5 & 6 front inner bearing assembly with 1.75" shaft as HY C125298WA (Chevrolet p/n 7450335). I found this link that lists lots of cross reference numbers for you to try and size dimensions for comparison.
http://www.kakapart.com/parts/bower-c125298wa.html
Search the big auction site for "wheel seal #3704483" and see if that's a match...per my book it was used on the 1-1/2 & 2 ton trucks from 1955-62.
Mike B smile
Mike B #1440591 Wed Feb 09 2022 06:55 PM
thanks Mike B that will give me a place to start
hippydave #1440592 Wed Feb 09 2022 07:03 PM
and 3B thank you as well
hippydave #1440599 Wed Feb 09 2022 07:38 PM
That is a fantastic truck.
58 Apache, long bed fleetside, V8 w/SM420
Drivable but the rear axle needs work.
Fibonachu #1441482 Wed Feb 16 2022 10:31 PM
thank you
Moderated by  69Cuda, Grigg
