The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (DennisM, 55_2nd_Series, 66rollback, carbking, 32vsnake, Fox, 1 invisible), 85 guests, and 3 robots.
Forums59
Topics128,614
Posts1,041,935
Members46,061
Most Online1,229
Jan 21st, 2020
Last time out with my tow rig I lost the front pass wheel bearings does anyone hae part numbers for these and the hub seal? Thank You
3B Offline
Hy hippydave, there are a couple of different axle possibilities for your truck, could you give us any numbers off of the bearings?
Pull the good side hub and repack the bearings. While you're in there, copy the numbers of the undamaged parts. Any bearing manufacturer should be able to provide an interchange, and seals can be ordered by dimensions.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
hi 3B thanks for the info on the master cyl heres an up date on that the reman is out of stock in the whole US but the new is in stock and dropped in price to $117 no core so will have Monday Thank You but as far as the inner bearing came out as steel puddles and balls and the seal face is gone so I need to do as Hotrod Lincoln said and strip down the other side and get numbers was just hoping to cheat
Moderated by  69Cuda, Grigg
