The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (55shaker, Chris's 46 / 515, buoymaker, JW51, klhansen, 1950 FC253, 1 invisible), 91 guests, and 3 robots.
Forums59
Topics128,595
Posts1,041,742
Members46,055
Most Online1,229
Jan 21st, 2020
Page 3 of 4 1 2 3 4
mdkelley #1438148 Fri Jan 21 2022 03:25 PM
Originally Posted by mdkelley
Will NAPA have rebuild kits for the hydrovac and the wheel cylinders, or just rebuild services?
You can get wheel cylinders and master cylinder pretty easily. The booster you're going to have to put in the mail or buy a rebuild kit off the internet.
There is a bunch of factory documentation for changing tires on factory wheels. Logging chain wrapped around it is a good safety precaution. Initial inflation is the more dangerous part. There is only certain advice regarding those wheels allowed here - but I was able to confidently put new tires on my truck.
mdkelley #1438170 Fri Jan 21 2022 07:18 PM
Struck out multiple times today. Called two Schrader locations, Saginaw Truck parts (a medium/heavy truck salvage yard), a couple local yards, tire shops... no one had any 6 lug 22.5 wheels or even any suggestions of where I could call. No one even knew any yards that deal in medium duty buses, box trucks, etc, either. I haven't called the bus garages yet but most buses that are in operation around here are the newer 10 lug stuff from what I see on the roads. There aren't any older buses in operation around here and most garages don't have room to store any obsolete parts that they can't use, they usually scrap that stuff for beer money. I know people have found these wheels but what I am reading online all seems to be 10-15 year old posts about how plentiful these are (or were). My guess is when scrap steel was way up 10-12 years ago a lot of these got turned into cash.
I will keep looking but sounds like I am going to be kind of forced into learning how to deal with these widowmakers for now and keep my eyes and ears open for some wheels or swap out the I beam and rear end for some more modern 10 lug stuff.
mdkelley #1438171 Fri Jan 21 2022 07:35 PM
Read the factory documentation for your wheels. Rust at the mating/locking surfaces is a problem that significantly increases the danger. You won't know how badly they are deteriorated until you break them down. If they are badly corroded, they wont lock back together the way they were designed. You can PM me for other questions.
mdkelley #1438175 Fri Jan 21 2022 08:05 PM
are the military style split ring 20" wheels any better? I am finding those for pretty reasonable prices (shipping will probably hurt but oh well)
mdkelley #1438214 Sat Jan 22 2022 01:54 AM
If the military rims are a multi piece lock ring type they are still serviceable...there are millions of them still on the road. The RH-5's are the only one's that I know of that are no longer legal, they have the 2" wide raised band running around the center of the rim...if they have a lock ring out at the tire bead they are NOT RH-5's and are OK to use.
Remember ALL multi piece rims need to be inflated in a safety cage...be safe! If you aren't comfortable mounting this type of tire get professional help...
Mike B smile
asilverblaser you said you could get master cylinders easy I have a 58 Viking 60 in need of a rebuild or new MC as well as frt wheel bearings where do you recomend
mdkelley #1439005 Thu Jan 27 2022 03:25 AM
I haven't started looking for master or wheel cylinders yet, or bearings for that matter. Probably be best to start a new post asking that, or maybe a search of all posts.
mdkelley #1439082 Thu Jan 27 2022 10:54 PM
would like to know what ever you find out. Iam currently looking for the same for my 58 viking 60
mdkelley #1439119 Fri Jan 28 2022 04:00 AM
3B Offline
Hy hippydave, the Napa part number for a re-manufactured master cylinder for your 58 Viking 60 is NMC P21698 $46.49, their part number for a new master cylinder is NMC M21698 $154.49, there was no mention of core costs. It is not the best idea to tag onto someone elses post and ask questions, please start your own posts, there is a better chance your questions will be noticed and answered, hope that helps.
3B #1439195 Fri Jan 28 2022 10:24 PM
thank you for the pt numbers and yea I would start my own thread
but havent figured out how yet Im a nubie and not all that computer savy yet
Page 3 of 4 1 2 3 4
Moderated by  69Cuda, Grigg
