The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Thinking again ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (NJC, 78buckshot, rgie, DougH6100, Paul_WNC, 1 invisible), 62 guests, and 3 robots.
Forums60
Topics127,583
Posts1,032,706
Members45,812
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Add petcock to bypass filter?
#1437742 Tue Jan 18 2022 04:08 PM
JW51 Offline OP
My canister filter (a Fram) has a little drain plug near the bottom. I’ve never used it, rather using a Turkey baster to suck the thing empty.
Got to thinking, could I use a radiator-style petcock in place of that little plug? Can those be trusted with oil? I’d spend the $5 on a petcock to reduce the mess. Not going to spend the $30 or so on a Fumoto style valve.
Re: Add petcock to bypass filter?
JW51 #1437745 Tue Jan 18 2022 04:23 PM
I wouldn't bet my engine's life on a radiator petcock, but a 1/8" pipe stainless steel or brass ball valve would probably work. There's lots of them on Ebay for a bunch less than 30 bucks, though! Take the handle off to keep it from getting moved accidentally and either store it in the tool box or use a Crescent wrench to turn the valve.
Edit: I just found several there for under $10.00 and one for $6.95. The ones with a male pipe thread will screw right into the filter housing without a nipple
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
JW51 #1437755 Tue Jan 18 2022 05:01 PM
JW51 Offline OP
What about this?
https://www.amazon.com/LASCO-17-0901-8-Inch-Female-Thread/dp/B008E33VFG/ref=mp_s_a_1_13?crid=3U237V6O9BVD1&keywords=1%2F8+npt+ball+valve&qid=1642525187&sprefix=1%2F8+npt+ball%2Caps%2C176&sr=8-13
JW51 #1437758 Tue Jan 18 2022 05:43 PM
Yep, that would work. It's got a pressure rating far above stovebolt oil pressure, and since most canister drain plugs are 1/8" NPT it should thread right in.
Kris Kristofferson
JW51 #1437760 Tue Jan 18 2022 05:51 PM
Ex Hall Monitor
I have a small brass ball valve on both of mine.
Let's go Jared!
JW51 #1437767 Tue Jan 18 2022 07:09 PM
Stir up a little solvent like Diesel fuel or Mineral Spirits in the canister before opening the drain valve and you can wash the inside before you drain it. The output orfice in the standpipe is way up the tube so there's no danger of contaminating the crankcase.
Kris Kristofferson
JW51 #1438404 Sun Jan 23 2022 03:01 PM
JW51 Ball valve works good ,take handle off or just plug it.
JW51 #1438491 Sun Jan 23 2022 11:09 PM
How big is the hole through the little petcock? Those oil filters are prone to being sludge pots. I am wondering if it will flow.
JW51 #1438508 Mon Jan 24 2022 12:29 AM
Ex Hall Monitor
I put barb fittings on the ball valves and run a length of fuel line from the fitting down to the oil drain pan during oil changes so the filter housing drains while the pan drains.
Let's go Jared!
JW51 #1438511 Mon Jan 24 2022 12:59 AM
JW51 Offline OP
That’s what I had in mind. I make a terrible mess every time I open the canister. Did it again today.
Page 1 of 2 1 2
Moderated by  Woogeroo
