The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (55shaker, Dodgecummins, buoymaker, Csims, D B Cooper, aircommando462), 119 guests, and 3 robots.
Forums60
Topics127,512
Posts1,032,081
Members45,794
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Getting bed sides verticle?
#1438349 Sun Jan 23 2022 01:00 AM
Getting bed put back together. Things are fitting decent. I have all fasteners loose fitted.
When I tighten things home do I just pull the top of the bedsides in to where I want them and tighten the bottom bolts on the rear cross member?
1966 C-10 Step Side. 283, 4spd, 3.73 gear. 60K miles prior to restoration. 507 Paint Code. Currently in 10,000 pieces.
Transmission is done! Rear Suspension is done! Wheels are done! Bed bodywork is done! Soon to order a 383 crate.
Re: Getting bed sides verticle?
Ferris Bueller #1438367 Sun Jan 23 2022 03:22 AM
That's the normal practice - square the sides up and tighten the bolts. On AD beds, the rear of the bedside was also welded to the rear cross sill. Don't know if that's what was done on your year range.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Ferris Bueller #1438388 Sun Jan 23 2022 11:22 AM
I used a strap to pull in the top of the bed side. Worked easily.
HB
1966 Chevrolet K-10
Flappy Fenders
In the Stovebolt Gallery [stovebolt.com]
More pictures on Photobucket [s160.photobucket.com]
1962 Chevrolet C10
1962 Suburban
Ferris Bueller #1438407 Sun Jan 23 2022 03:14 PM
Yes, the rear lower cross piece that’s below the tailgate is welded to the bedside in a 1965 C10. As you tighten the bolts, check squareness by measuring from front to rear corner diagonally and make them match.
Ferris Bueller #1438466 Sun Jan 23 2022 08:14 PM
It was welded on the side that had damage, but not on the side without when I took things apart. Mine is a 66. If I don't like how it is once final assembly is done I guess I can always go under and weld it in.
Not much holds these bed sides up. No running without a tailgate, that's for sure.
I think it fit well enough together to move onto the next step. I got primer on remaining pieces and will order the tintable liner tomorrow.
I am going to spray everything once while it is in pieces to make sure there is a durable coating on all sides in holes etc, then assemble. Once assembled I am going to spray additional coats to make sure it all matches.
I think some of the rot issues we have is they primed, but assembled and then painted. I see no evidence of paint between the panels where they attached. Hoping I am setting the stage for a long trouble free finish.
Ferris Bueller #1448352 Sat Apr 16 2022 08:18 PM
I would loosen the front bed bolts too. Then tighten the bed where you want it. The tighten the front and rear bolts. Then weld the rear cross brace.
Ferris Bueller #1448515 Sun Apr 17 2022 10:53 PM
Hmmm. I am going to paint and then assemble, with the intent of painting another coat after assembly. I guess I could grind off and weld and then shoot it again.
Moderated by  Hambone
