The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Steelonsteel, booger, Fox, latroca52, 1 invisible), 93 guests, and 3 robots.
Forums60
Topics127,485
Posts1,031,818
Members45,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1951 GMC 354 24 frame modifications
#1436994 Wed Jan 12 2022 02:27 PM
dsword Offline OP
Hello,
I recently purchased a 1951 GMC two ton flatbed dump truck. The frame has been modified with an additional piece of steel added the makes the frame about 11 inches tall instead of the usual 8 inches. The extra piece runs from just behind the rear front spring hanger to just in front of the front rear spring hanger. Could this have been added as part of the dump bed modification?
David Sword
Re: 1951 GMC 354 24 frame modifications
dsword #1437001 Wed Jan 12 2022 03:39 PM
Yes, that was a common practice to beef up the frame rails for handling heavier loads.
dsword #1437308 Sat Jan 15 2022 12:51 AM
My Dad called it a fish plate. They were factory installed on some trucks our 1946 COE, for example.
Mike
Direct email ml.russell1936@gmail.com
dsword #1437324 Sat Jan 15 2022 02:25 AM
Here's a pic of a welded fishplate. It's a doubler used when a frame extension is added, either bolted or welded.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
dsword #1437384 Sat Jan 15 2022 03:16 PM
Another example of frame cut and doubling, 4’ shortening in this case rather than moving the axle fwd and cutting back end off. Flange nuts and bolts, joint welded.
Ed
dsword #1437678 Tue Jan 18 2022 12:11 AM
dsword Offline OP
Here are some pictures. It is an L-shaped piece that runs the full length between the front and rear spring hangers. It is almost 12” tall instead of the standard 8”. It is rivited on.
dsword #1438345 Sun Jan 23 2022 12:42 AM
dsword Wow tuff frame,looks like your rubber might be good too. I guess that added hight on your frame can only help,most doubled frames are a channel that fits right over the main frame. there are lots of hoists out there should be able to find a good used one.
dsword #1438359 Sun Jan 23 2022 02:05 AM
Frames like yours were common on farm trucks. I have several with dump boxes and reinforced frames.
https://flic.kr/p/5PNznV
https://photos.app.goo.gl/1GjF1Ca8LDEnDUC87
https://photos.app.goo.gl/FT7CCM1eVLgzRcfB9
klhansen #1438726 Tue Jan 25 2022 05:00 PM
klhansen Have had em just like that,I think it's important to use a-36 frame steel that is stretchy to make those. We used to just cut them out of junk frame,weld with 7018.
Moderated by  69Cuda, Grigg
