The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (KEVINSKI, 55shaker, DavidBraley, Justhorsenround, Bill Trotter, 1 invisible), 82 guests, and 4 robots.
Forums60
Topics127,506
Posts1,032,027
Members45,793
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Cab Corner Hole
#1437971 Thu Jan 20 2022 01:32 AM
I thought I had discovered a small hole in the bottom of the cab corner but I looked at it closely today and it may just be a drain hole that has been blocked by crud?
Is it? It is a 65 C10. Sorry for the rookie question.
1965 Chevy C10 Longbed Fleetside
(Engine needed, originally 230)
Re: Cab Corner Hole
WarEagle1 #1438010 Thu Jan 20 2022 12:09 PM
Pic? I haven't dug into mine, but that area is packed with sand for sure.
1966 C-10 Step Side. 283, 4spd, 3.73 gear. 60K miles prior to restoration. 507 Paint Code. Currently in 10,000 pieces.
Transmission is done! Rear Suspension is done! Wheels are done! Bed bodywork is done! Soon to order a 383 crate.
Re: Cab Corner Hole
WarEagle1 #1438014 Thu Jan 20 2022 01:13 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
These trucks had vent holes in the cab corners. We need to take the time to clean them out every so often so they can do their job.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Re: Cab Corner Hole
WarEagle1 #1438021 Thu Jan 20 2022 03:06 PM
Heed Martin's excellent advice.
My theory as to why many cabs are rusted-out in those lower-rear cab-corners is because the "weep holes" got blocked.
My additional theory, based on observations of those lower rear cab corners (in upstate NY) is that they got stopped/plugged due to mouse/rat/squirrel nests. Their nests clogged/stopped the draining. And, some of those varmints censored where they nest (especially in a really cold environment).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Cab Corner Hole
WarEagle1 #1438024 Thu Jan 20 2022 03:19 PM
Thanks for the replies. I'm relieved that it is just a vent/drain hole. When I thought it was a rust hole I was really surprised because my cab corners are solid.
I'll try to make a pic but it will be hard to see. The exterior of the hole is behind a "double wall". The best way I've found to see it is by shining a light from underneath.
Re: Cab Corner Hole
WarEagle1 #1438026 Thu Jan 20 2022 04:16 PM
I’ll contribute something although it’s worthless info. I think these trucks were built with A. I. (artificial intelligence). If the drain holes get plugged, the computer brain turns on the “drain hole mode” and the floor and rockers will make another functional drain hole. I just can’t find that darn computer.
I have drain holes along the PS rocker and another at the driver toe board. I hit a puddle once and my foot got wet.
Moderated by  Hambone
