We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
12 members (artinva, Fox, buoymaker, Bob Kirk, J M, FrankenChevy, 1 invisible),
102
robots. |
Key:
Admin,
Mod
Forums60
Topics127,485
Posts1,031,816
Members45,791
Most Online1,229 Jan 21st, 2020
 Re: Resize a stock steering wheel
OP
Thanks for all the feedback on this topic I will do some more research on another steering wheel that will work well with my stock steering column.
This is no longer fun
Curmudgeon
FYI:
I think Classic Truck Magazine sold out to Motor Trend (the link I posted above).
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
I found a wheel from a Fiero at Pick your Part. It has 3 spokes similar to the original wheel and has a slight dish to it. I replaced the horn cap with one from a mid 70's Camaro and used a bowtie emblem in the center. Also installed the stock turn signal cancel plate and it works well. Fred
I saw a thread elsewhere where a 1960-66 C10 steering wheel that was “shrunk”. The work was more than I would want to put into a project, but the result looked nice. The diameter of the wheel was made smaller by cutting the spokes shorter and then re-welding them to the hub. Sections were removed from the outer ring and then the pieces that remained were placed in a jig to align them so they could be welded together again into a smaller ring. Most of the original wheel outer plastic (or whatever polymer it is) was retained but the gaps where the welding occurred were filled with an epoxy much like JB weld and shaped to resemble the original wheel material. All done and painted it looked nice but not what my time is worth. Just saying.
A smaller diameter aftermarket wheel is worth the money IMO. I will say that the aftermarket wheels do a poor job at helping the average Joe figure out how to make the horn work again when installing a new steering wheel. That’s been my stalling point when I think about installing the new wheel I still have in the. I’d on the shelf.
Curmudgeon
The link is on page one if you want to use it for reference.
The link is on page one if you want to use it for reference. Yes indeed. I passed right by that link as I scanned the replies. Looks to be the same set of pics I saw some time ago. Good reference! Well, my description pales to that thread with pics.
Itroca 52 Sure you can re-size a steering wheel,get one that needs help,cut it down to your dimensions weld metal frame. Make a mold the shape you want pour in epoxy,file and sand,paint. Not rocket science !!
