We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
7 members (MikeE, 53 green 1- ton, Bill Trotter, Ricster, Bill Marlow, joe apple, 1 invisible),
65
robots. |
Key:
Admin,
Mod
Forums60
Topics127,583
Posts1,032,707
Members45,812
Most Online1,229 Jan 21st, 2020
 Mouth wrote a check
OP
Younger small guy that is a wiring whiz said he would knock out a 53 3100 (12v, alternator conversion) new wire harness in one day so I had to up the ante to double his salary for half a day. Truck comes in next week and he has a 10 circuit harness, bulbs, seal beams, pre-made alternator bracket, fender terminal blocks, and even the loom to inner fender and frame clamps all laid out on the big table. Truck remains one tail light and no turn signals so I think he saw a mark in the making. We agreed fishing the dome light wire up through the pillar would be time exempt. As Flip Wilson said, "Don't let your mouth write a check your body can't cash".
Evan
 Re: Mouth wrote a check
A smarter monkey would've pulled a fish wire in with the old wire during disassembly. Or, left the old wire as a fish. The fastest way is to send the fish up from the bottom as fishing from the top ends up at the traffic jamb that is the lower windshield joint on the 3100 series. But, I'll never admit to having experience with any of this stuff.
I use a retired speedometer cable to find its way up through an A pillar. It works a lot better than other methods I've tried. Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
WAG MORE- - - - - -BARK LESS!
Cletis (Rest his soul) used to describe a method they used fishing lines on aircraft where they poked a string in the starting point and hit it with an air line. He said it worked amazingly well.
A cotton ball tied to the end of a string blown thru an electrical conduit has been used for years. Once the string comes out, tie a heavier cord on the string and pull that thru, etc. as needed. Then the wire (or wires) get pulled thru.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
OP
A case of where the owner done us a "favor" by removing every inch of the original harness, so some fishing time is necessary.
Evan
