The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Whatcha doing now?
What did you get done on your Bolt today? - 2021 and later
The original thread is still in tact and we have 14 pages already for this time frame. A "mini-Project Journal" if you will.
Stovebolt driving report
Started by Cletis in 2012 - 36 pages and going strong!
Who uses their truck as a truck - 2021 and later
Re-started this thread. Three pages and counting.
Bolters in the Side Lot
are planning get togethers and what not. See who's near you.
Stay busy; keep warm!
Share your enthusiam.
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
8 members (Justhorsenround, Joe Q, Gdads51, DennisM, HFfarms, 1 invisible), 203 guests, and 3 robots.
Forums59
Topics128,331
Posts1,054,143
Members46,614
Most Online1,229
Jan 21st, 2020
Page 2 of 3 1 2 3
KEVINSKI #1437493 Sun Jan 16 2022 02:23 PM
kevinski Use a careful low pressure flush,it''ll act like a water heater you'll get some dirty water then run clean---not even close to clean !!IF IT FLOWS AND HEATS GOOD better leave it alone. On your block some time when you have the head off you can hurt that sludge that piles -up around 5 and 6 with a big screwdriver and hammer. Outside of that be glad it will run cool !!
KEVINSKI #1437691 Tue Jan 18 2022 01:49 AM
Got the heater pulled apart and found a few surprise’s.Anyone change the hub on the squirel cage the origional had a wood screw screwed into it and the motor shaft was brazed with melted the alloy hub .I think I can drill a bushing and tap a set screw then weld it on the squirel cage.
KEVINSKI #1437697 Tue Jan 18 2022 02:29 AM
7
Be real careful with heat on the blower wheel, it will warp and you'll have a heck of a time trying to make it run true. Maybe soft solder or silver solder would be safe.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto, 1978 Yamaha DT175, 1999 Harley Davidson Softail Fat Boy
KEVINSKI #1437701 Tue Jan 18 2022 03:14 AM
Good point thank you,I may try to rivet it or solder like you suggested
KEVINSKI #1437703 Tue Jan 18 2022 03:18 AM
If you have a spot welder that will reach into the squirrel cage, that would work. Wouldn't be an issue with warping the hub. That might even be an issue with a torch used for soldering.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
KEVINSKI #1442280 Wed Feb 23 2022 03:45 AM
JW51, I don't know about 54' but my 49', which has the same heater, has a valve control knob on the dash to control flow of coolant through the core. I can shut it off completely or adjust the flow. It has an air filled flat canister about the size of the diameter of soup can with a copper tube back to the valve that will help regulate the flow based on cabin temperature. Kind of an automatic temp control. All factory.
1949 Chevy 3600
1975 W-25 Hurst Olds
1991 Chevy Silverado
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
I'm a GM man!
KEVINSKI #1442643 Fri Feb 25 2022 02:42 PM
Moderated
heater al new 53 recirulating on 53 chevy truck but not much air coming through defroster vent
KEVINSKI #1442686 Fri Feb 25 2022 09:03 PM
Unfortunately my heater control disappeared so I was going to use a modern valve .The defrost control had two types one a leaver on the unit itself and the other by a cable that I think was under the dash by the heater switch.
KEVINSKI #1442693 Fri Feb 25 2022 10:34 PM
If you can find an original Ranco heater valve the rubber seal is still available. I think I paid about 8 bucks at NAPA for one.
1949 Chevy 3600
I'm a GM man!
KEVINSKI #1442982 Mon Feb 28 2022 05:37 PM
I will be tracking your solution for the squirrel cage attachment. Mine was not as bad as yours but it is definitely loose, or at least it is now after I finally got it removed from the shaft.
1949/50 3600 Project
Page 2 of 3 1 2 3
Moderated by  ndkid275, Phak1
