The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (68ironhead, coilover, David Daoust, baldeagle, BernieB, 3 invisible), 105 guests, and 3 robots.
Forums60
Topics126,134
Posts1,019,638
Members45,442
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Distributor gear
#1437327 Sat Jan 15 2022 02:40 AM
The 235 I’m working on had sat for many decades. Condensation did considerable damage necessitating a complete overhaul. My distributor gear had some rust on it and I’d like to replace it. Does anybody know where I can find a new gear? The distributor is in great condition otherwise. I’ve looked at all the online places I know of, but no one sells or lists the gear.
Re: Distributor gear
lumbersawyer #1437345 Sat Jan 15 2022 04:07 AM
What year is the engine? There has ben a ton of discussion about steel VS cast iron distributor gears, but unless you're running a steel alloy cam from a 216 or early spray oiler 235, the same gear that fits a 250 or 292 distributor will work. Those distributors will be simpler to find in a salvage yard or on Ebay than an early stovebolt unit in case you have to scavenge up a used one. Summit and JEGS sell a bronze gear for a 250 that will also work.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
lumbersawyer #1437351 Sat Jan 15 2022 04:25 AM
It is a 59 235
lumbersawyer #1437381 Sat Jan 15 2022 02:54 PM
Check the part number on your distributor. It should end in 2401. If it does, the correct part number is delco 1929578.
There is one for sale on eBay as we speak for 20.00
https://www.ebay.com/itm/403118585570?epid=1953301093&hash=item5ddbbd76e2:g:rI8AAOSwiR9hLaCP
The below is a thread from 2020 that you may find helpful
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1357754/replacement-distributor-gear.html
Mike
lumbersawyer #1437388 Sat Jan 15 2022 03:52 PM
Thanks much, I purchased it.
Moderated by  Woogeroo
