The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (Cu29head, 2ManyTrucks, Chris's 46 / 515, DennisM, 4 invisible), 125 guests, and 3 robots.
Forums60
Topics126,136
Posts1,019,641
Members45,442
Most Online1,229
Jan 21st, 2020
Image Posting Policy
engine 216 235 292?
#1437328 Sat Jan 15 2022 02:44 AM
namyaw Offline OP
Moderated
i have a 1953 Chevrolet truck 3500. what to replace 216 and no babbitt bearings. engine suggestions? thank you
Re: engine 216 235 292?
namyaw #1437333 Sat Jan 15 2022 03:05 AM
Ford 300!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
namyaw #1437335 Sat Jan 15 2022 03:15 AM
2JZ-GTE
namyaw #1437338 Sat Jan 15 2022 03:33 AM
Jeep 258
Kris Kristofferson
namyaw #1437410 Sat Jan 15 2022 07:53 PM
You boys aren't helping. Y'all snowed in or something?
namyaw #1437420 Sat Jan 15 2022 08:34 PM
I strongly recommend a 235, or a 261 if you can find one. These are both bolt-in swaps. I currently have a 1948 235 truck engine (babbit/ splash-oiler) in my '53 3600. It is a very low-mileage engine I picked up from a guy who was swapping a small block into the 1.5 ton truck it came out of. I could not be happier with the way my truck runs, and the power this older 235 has! I use my truck as an actual work truck, and sometimes do drive on the interstate, as much as 70 miles at a stretch. I'm running a Carter YF carb, btw, and I also have the coveted 4.10 rear end gears. This truck will easily do 65-70 mph (with the tallest tires I could fit, I believe they're 235/75 R 16s).
230/250/292 will fit, but if I remember right from reading posts here, it will require moving the radiator forward. In my opinion, this is a better option than a V8. At one point, years ago, a mechanic friend talked me into putting a 350 sbc in this truck, after I had very naively thrown a rod in the late 50's 235 it had when I bought it. Sbc swaps involve moving the steering gear and fabricating motor mounts. In my case, I never got the 350 to cool properly and wound up fatally overheating it and ruining one of the heads. If I knew then (roughly 20 years ago) what I know now, I would have just had that first 235 rebuilt. In any case, after my ill-fated few years with the V8, I went back to Stovebolt 6s and will never look back.
1953 3600 Pickup [stovebolt.com]
1946 Fleetline Aerosedan
1948 Hudson Commodore
52Carl #1437429 Sat Jan 15 2022 09:20 PM
Not yet but it's supposed to be on the way. How about a Cummins 4BT? 170 HP, 420 ft/lbs torque, no computer, and much better fuel mileage than any gas engine that comes anywhere close in performance to it. Think outside the GM inline six box!
Kris Kristofferson
namyaw #1437449 Sat Jan 15 2022 11:30 PM
I'm voting for the 292. I tend to hoard them but the last one I bought on ebay in running condition with compression test was $500 delivered. There is some fab work involved in it but it's a great platform. Maybe someday you want to say bump it up to 1000 HP or so then you're ready. So there's that.
Tyler Watts #1437469 Sun Jan 16 2022 02:47 AM
namyaw Offline OP
Moderated
thanks for the the advice.
Moderated by  Woogeroo
