The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (Green_98, glenns towing, Dirtdevil, dsword, 68ironhead, coilover), 119 guests, and 3 robots.
Forums60
Topics126,135
Posts1,019,639
Members45,442
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 31 of 36 1 2 29 30 31 32 33 35 36
Re: 1948 Thriftmaster 3/4 ton - Poncho engine swap
Goach2 #1437276 Fri Jan 14 2022 07:00 PM
Goach2 Offline OP
So I ordered two oil filters online from a Canadian site, they got back to me and said they didn't have any in stock, but would send me two Wix's as replacement for same price smile I also called my local CT and they ordered in a Fram for me, which I will use for break-in and then go with the better filters after that. Best-case scenario, I 'could' be up and running tomorrow...
1948 Chevrolet Thriftmaster 3/4 Ton
There are only 10 types of people in this world, those who can read binary and those who can't.
Goach2 #1437281 Fri Jan 14 2022 07:37 PM
👍 looking forward to hear you got it running
kevinski 1954 GMC 9300 Welcome to the virtual Garage [stovebolt.com]
Goach2 #1437376 Sat Jan 15 2022 01:54 PM
Goach2 Offline OP
Goach2 #1437382 Sat Jan 15 2022 02:54 PM
Nice job must have heat in there cold is headed your way -30 c with wind -37 .
Goach2 #1437416 Sat Jan 15 2022 08:10 PM
Goach2 Offline OP
Ya, looks like substantial storm headed this way.
So I got plugs cleaned up and gapped, same with the points. Oil filter came in too, so ready to pour that in. Sounds like 7 quarts is right, based on other posts. I can't trust the dipstick yet, as I had to add one since it was missing and it's possible something is off. I'll put in 7 and we'll see what she looks like.
Goach2 #1437424 Sat Jan 15 2022 08:39 PM
Goach2 Offline OP
Being a Pontiac engine, looks like 5 quarts is what it actually holds. I just put in T liters, hope that's ok!
[img]https://www.stovebolt.com/ubbthread...umber/38680/filename/20220115_153820.jpg[/img]
Goach2 #1437428 Sat Jan 15 2022 08:58 PM
Yea was just going to say but before I posted I found this on the Pontiac form . That way you can check your dipstick after the proper amount of oil is put in as it may be the same as one of your old motors but it I think it also depends if the oil pan is the same .
Goach2 #1437510 Sun Jan 16 2022 05:28 PM
Goach2 Offline OP
How long should it take to get fuel to the pump? Any way to test that I installed it right?
[img]https://www.stovebolt.com/ubbthread...umber/38728/filename/20220116_122703.jpg[/img]
Goach2 #1437536 Sun Jan 16 2022 09:05 PM
Goach2 Offline OP
She popped off, but foiled by a dead battery...
[img]https://www.stovebolt.com/ubbthread...umber/38738/filename/20220116_160412.jpg[/img]
Goach2 #1437550 Sun Jan 16 2022 11:44 PM
Goach2 Offline OP
Tripped up by a bad charger. In the meantime, clutch and pressure plate installed. Also did the 'cold' valve adjustment from the manual. Hopefully soon it'll fire. Then on to the transmission...
Moderated by  HandyAndy
