We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,583
Posts1,032,707
Members45,812
Most Online1,229 Jan 21st, 2020
 HD clutch
OP
There have been a couple of threads recently discussing the oddball 9-bolt pressure plates and HD clutches that were available on some of the big bolts. Can anyone think of a reason a regular flywheel couldn't be drilled and tapped for the much less expensive and more available 6 bolt clutch cover that's used on the small block V8's from the 60's and beyond that works with the 11" disc? The transmission input spline is the same, and if an accurate drill/tap job is done, it seems that would be an alternative to trying to find the 9 bolt cover, or getting one rebuilt. A dividing head and a Bridgeport mill or a heavy duty drill press should be all that's required to get the hole spacing right. Comments? Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
WAG MORE- - - - - -BARK LESS!
 Re: HD clutch
My clutch is the 9 bolt. I noticed the other day that the flywheel is also drilled and taped for a 6 bolt clutch. I have a 10" rotary table and setting up to do that would not be very hard to do at all. I have a DRO too, so, once you find center of the flywheel it is simply one move and 60 degrees between holes.
 Re: HD clutch
I have an 11 inch flywheel that had once been used in a 1953 Corvette that got totalled. It had been drilled and tapped for different pressure plates when I got it. Don't know why, but that's the way it was done. Whatever the story, the holes looked to be all the same. I ended up using a 6 bolt pressure plate for a Chevy V8 and a disc for a Chevy van (I needed a spline that would fit the T5). Once I sorted the throwout bearing and clutch linkage rod length, it was all done.
Jon
1952 1/2 ton with 1959 235 T5 with 3.07 rear end
