The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (55shaker, FrankenChevy, DavidBraley, Justhorsenround, Bill Trotter, 1 invisible), 79 guests, and 4 robots.
Forums60
Topics127,506
Posts1,032,027
Members45,793
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1957 truck V8 accelerator linkage
#1436451 Fri Jan 07 2022 08:12 PM
I’m looking for the original factory linkage from the gas pedal to the carburetor for my 1957 3100 with a 1964 327 V8. If it also has the throttle linkage, that would be great.
Thank you,
Larry
Re: 1957 truck V8 accelerator linkage
LAJones48 #1436911 Tue Jan 11 2022 04:21 PM
3B Offline
Hy LAJones48, Jim Carter Classic Truck Parts lists their part number HP142 as the kit which contains most of what you are looking for, hope that helps.
LAJones48 #1436929 Tue Jan 11 2022 07:03 PM
Thanks for your reply. I have one of the repro linkages. I’m trying to locate an original to either use or to help me see what’s different about the repros.
LAJones48 #1436946 Tue Jan 11 2022 10:04 PM
Workshop Owner
The 327 wasn't available until '62. If V8 equipped, your '57 could have only had a 283. SBC V8's for those years are mostly the same, but the carburetor and intake may be different.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
LAJones48 #1436950 Tue Jan 11 2022 10:24 PM
The re-po,s don't fit as they come. They have to be disassembled & assembled correctly. I assume it is to save space when shipping.
George
1972 Chevy c10 Cheyenne Super
LAJones48 #1436962 Wed Jan 12 2022 01:14 AM
Hi George. I’ve heard about the reassembling issue, but I haven’t been able to figure out what needs changing. I bent the tabs that hold the bracket to the firewall, but the the linkage was not moving freely afterwards. Do you have any info on what needs to be rearranged?
Thank you,
Larry
LAJones48 #1436981 Wed Jan 12 2022 03:32 AM
Its been so long since i did one I can't remember. I know its pretty hard getting it installed with the engine in there. I don
t have any of that model any more. Maybe another Bolter can take a photo of it.
George
LAJones48 #1437005 Wed Jan 12 2022 04:57 PM
I alright. Thank you for the heads up.
Larry
LAJones48 #1437146 Thu Jan 13 2022 09:28 PM
As George stated they are not assembled correctly and the mounting is designed for a flat firewall but TF trucks are curved.
If you are converting from a 6 to a V-8, it may be a problem as some firewalls are drilled for the bracket and some are not.
It's difficult to drill holes in the correct location with the engine in place.
The aftermarket ones can be made to work with some modifications. I have not been able to find any originals on the conversions I have done.
Fred
Moderated by  John Milliman
