The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Thinking again ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (coilover, KevinW, dunfire, 51Craig1Ton, 53 green 1- ton, 2 invisible), 72 guests, and 3 robots.
Forums60
Topics127,583
Posts1,032,707
Members45,812
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1962 235
#1436640 Sun Jan 09 2022 05:44 AM
Moderated
I'm currently rebuilding a 235 which from the identification numbers I'm finding is a 1958-1962. The engine came with my 1950 3600 that I'm rebuilding. The engine was separate and locked up, long story short the engine had been sitting outside with no oil in it for a long time before I got it and I recently got it all torn apart and have to replace almost everything on the inside. As I'm looking for parts on sites such as Advance Auto and NAPA they require me to put in a year make and model of the vehicle but I'm not sure what the engine came out of. Should I by parts that are consistent with the truck I have or just pick a truck from the 1962 era to find parts for it. I've tried searching under both searches and finding such things as the camshaft that have different model numbers depending on the year I select.
I also found from sites like Summit Racing it will let me search by engine and there are a couple models of 235 that are 3.8L and 3.9L. Does anyone know which category this engine would fall under
Chris
1950 Chevy 3600 (Rebuild in progress)
1962 235 (Rebuild in progress
Re: 1962 235
CShepard #1436656 Sun Jan 09 2022 01:24 PM
There is a block casting date behind the starter. That will pin point the year of the engine.
http://1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
Then request parts for that year engine. If it has hydraulic lifters then it is most likely from a car. If solids, then most likely a truck... The were changes made to the rocker oiling, so this link could be helpful.
http://chev235guy.blogspot.com/?m=1
I hope this is useful. Good luck.
Professional Novice
Re: 1962 235
CShepard #1436688 Sun Jan 09 2022 04:59 PM
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: 1962 235
CShepard #1436694 Sun Jan 09 2022 06:00 PM
Better link to my blog post about rocker oiling.
http://chev235guy.blogspot.com/search/label/235%20Rocker%20Oiling?m=0
My Blog
Re: 1962 235
CShepard #1436734 Sun Jan 09 2022 10:23 PM
Tim
Re: 1962 235
CShepard #1436745 Sun Jan 09 2022 11:19 PM
Moderated
Thanks all, this has been very helpful!
Re: 1962 235
CShepard #1436752 Mon Jan 10 2022 12:02 AM
Thanks Tim!
Together we will get things straight.
My Blog
Re: 1962 235
CShepard #1436764 Mon Jan 10 2022 01:03 AM
If you need to buy a new cam be mindful that in 1959 Chevy adopted the new cam that would remain the one for all 235s until they quit making the engine. It produces higher torque at lower rpm than the 56/57 or the 58 cam and it is the one you want...if you can find it. I'm in the process of trying to figure out what is happening at Melling. They were making one, but now they've substituted a different grind which doesn't look to me like it matches GMs specs.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: 1962 235
CShepard #1436809 Mon Jan 10 2022 04:58 PM
The 3.8 and 3.9 liter designations are both for the 235 engine- - - -people just fudge the conversion figures to suit themselves. A cubic inch is 16.4 CC's, and there's a thousand CC's to a liter, so you can do the math and pick which one floats your boat. Unless you get very lucky and find a set of "new old stock" hydraulic lifters, I'd strongly suggest going with a solid lifter camshaft. The Elgin E-293S cam is a clone of the 261/Corvette camshaft, and the Melling CCS-1 cam has a similar grind, with a bit more duration to the exhaust valve. Both of those cams will offer a power gain over the standard original equipment 235 cam without getting into an idle lope and loss of low end and midrange torque. RUN- - - -do not walk away from the cam Clifford sells- - - -anybody who has to lie about power gains and fuel mileage with no supporting documentation to sell a product probably shouldn't be trusted!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Re: 1962 235
CShepard #1436861 Tue Jan 11 2022 12:21 AM
It seems Elgin isn't making the E-293S camshaft any longer, Jerry. Do you know otherwise? Melling can make the CCS-1, however they are not doing so at this point. Please take a look at Melling CCS-6 and let us know what you think of that one. It is what Melling is offering as a replacement (hydraulic lifter cam) for the 235 from 1959 onward.
Jon
Page 1 of 2 1 2
Moderated by  Woogeroo
