The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (cassie, Bill Hanlon, Bruce36 1.5, bwilliams, buoymaker, 2 invisible), 95 guests, and 3 robots.
Forums59
Topics128,595
Posts1,041,747
Members46,055
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1436640 Sun Jan 09 2022 05:44 AM
Moderated
I'm currently rebuilding a 235 which from the identification numbers I'm finding is a 1958-1962. The engine came with my 1950 3600 that I'm rebuilding. The engine was separate and locked up, long story short the engine had been sitting outside with no oil in it for a long time before I got it and I recently got it all torn apart and have to replace almost everything on the inside. As I'm looking for parts on sites such as Advance Auto and NAPA they require me to put in a year make and model of the vehicle but I'm not sure what the engine came out of. Should I by parts that are consistent with the truck I have or just pick a truck from the 1962 era to find parts for it. I've tried searching under both searches and finding such things as the camshaft that have different model numbers depending on the year I select.
I also found from sites like Summit Racing it will let me search by engine and there are a couple models of 235 that are 3.8L and 3.9L. Does anyone know which category this engine would fall under
Chris
1950 Chevy 3600 (Rebuild in progress)
1962 235 (Rebuild in progress
CShepard #1436656 Sun Jan 09 2022 01:24 PM
There is a block casting date behind the starter. That will pin point the year of the engine.
http://1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
Then request parts for that year engine. If it has hydraulic lifters then it is most likely from a car. If solids, then most likely a truck... The were changes made to the rocker oiling, so this link could be helpful.
http://chev235guy.blogspot.com/?m=1
I hope this is useful. Good luck.
Professional Novice
CShepard #1436688 Sun Jan 09 2022 04:59 PM
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
CShepard #1436694 Sun Jan 09 2022 06:00 PM
Better link to my blog post about rocker oiling.
http://chev235guy.blogspot.com/search/label/235%20Rocker%20Oiling?m=0
My Blog [chev235guy.blogspot.com]
CShepard #1436734 Sun Jan 09 2022 10:23 PM
Tim
CShepard #1436745 Sun Jan 09 2022 11:19 PM
Moderated
Thanks all, this has been very helpful!
CShepard #1436752 Mon Jan 10 2022 12:02 AM
Thanks Tim!
Together we will get things straight.
CShepard #1436764 Mon Jan 10 2022 01:03 AM
If you need to buy a new cam be mindful that in 1959 Chevy adopted the new cam that would remain the one for all 235s until they quit making the engine. It produces higher torque at lower rpm than the 56/57 or the 58 cam and it is the one you want...if you can find it. I'm in the process of trying to figure out what is happening at Melling. They were making one, but now they've substituted a different grind which doesn't look to me like it matches GMs specs.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
CShepard #1436809 Mon Jan 10 2022 04:58 PM
The 3.8 and 3.9 liter designations are both for the 235 engine- - - -people just fudge the conversion figures to suit themselves. A cubic inch is 16.4 CC's, and there's a thousand CC's to a liter, so you can do the math and pick which one floats your boat. Unless you get very lucky and find a set of "new old stock" hydraulic lifters, I'd strongly suggest going with a solid lifter camshaft. The Elgin E-293S cam is a clone of the 261/Corvette camshaft, and the Melling CCS-1 cam has a similar grind, with a bit more duration to the exhaust valve. Both of those cams will offer a power gain over the standard original equipment 235 cam without getting into an idle lope and loss of low end and midrange torque. RUN- - - -do not walk away from the cam Clifford sells- - - -anybody who has to lie about power gains and fuel mileage with no supporting documentation to sell a product probably shouldn't be trusted!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
CShepard #1436861 Tue Jan 11 2022 12:21 AM
It seems Elgin isn't making the E-293S camshaft any longer, Jerry. Do you know otherwise? Melling can make the CCS-1, however they are not doing so at this point. Please take a look at Melling CCS-6 and let us know what you think of that one. It is what Melling is offering as a replacement (hydraulic lifter cam) for the 235 from 1959 onward.
Jon
Page 1 of 2 1 2
