We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,583
Posts1,032,706
Members45,812
Most Online1,229 Jan 21st, 2020
 If a diagnostic tool detects a code,
OP
and then the code is deleted is there a diagnostic archive, It is a 2008 HHR>
 Re: If a diagnostic tool detects a code,
As far as I know, you can't retrieve deleted codes from GM's, at least from I have seen using aftermarket scanners. At work, we delete all the time, when they come in a short amount of time, we work on them. Since all of ours are natural gas powered 6.0l's we get a lot of false codes.
Mixed Up
Ron is having a senior moment Martin. He will realize his mistake after he gets his morning nap in.  Don
OP
Nope Don I did not. I debated but I felt either way it might be deleted. At least I did not try and hide it. Thanks, Jon H, After I posted that was my thought. If it comes back on then have it read again. The car is one I bought for a friend 4 years ago and I now have one also, the same year. What she told me was their 2 codes one was the gas cap and the other she said it said crankshaft timing cover. Whatever that meant. Don the sad thing is when you do take a nap then you can't remember it.
duckduckgo the error code then the type of vehicle it is and the results should show what the fix is if you look through what others have done to repair.
OP
If you have access to a tech-2, you can pull "historic codes" which are ones that have cleared automatically.
If you clear the codes using a scan tool, they are generally gone until they get set again.
58 Apache, long bed fleetside, V8 w/SM420 Drivable but the rear axle needs work.
Mixed Up
Why is this topic in the Swap Meet now? It should be in the spoon. Don
