We are still asking: What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Hello, I recently purchased a 1951 GMC 2 ton flatbed dump truck with a 179 inch wheel base, fourteen foot bed and a two speed rear end. It has not run in fifteen years. The engine has 270 only stamped on the block near the distributor which makes me believe it had a factory engine replacement. The frame has been beefed up with a larger cross section added that runs from just behind the front spring hangers to just in front of the rear spring mounts. Does anyone know if this was a common thing to do? The truck came from eastern Oregon so is pretty much rust free except for parts of the floorboards and some surface rust. It needs a lot of rubber parts replaced but I am looking forward to getting it back to work.
Welcome! Gotts love those Big Bolts! Lots of good info to be found over on the Big Bolt forum. Stop in over there if you haven't already. Keep us posted on your progress, and be sure to post some pictures when you get a chance.
Genie: "I am the genie from a magic lamp and I have the power to grant you three wishes." Me: "I want to be rich." Genie: "OK, Rich, what's your second wish?"
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Welcome to the Stovebolt madness. There is no cure!
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily” ‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
Dsword, Welcome to the BOLT, you have a very sid looking truck there. Be sure to post your questions in the Big Bolts forum, lots of great folks there.
Craig
Come, Bleed or Blister something has got to give!!! 59' Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
