The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
E V E N T Highlight
Southern
"STOVEBOLT"
Jamboree 2022
July 8 and 9
Lebanon TN
The Southern Bolters are planning their area get together in
conjunction with the
Southeast Truck Nationals at Cedars of Lebanon State Park (TN)
Check out the details, with new info on the Southern Bolters forum.
Plenty of other events in the Side Lot
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Hotrod Lincoln, 49nut, 65c20, Harold46, Maxine, buoymaker), 93 guests, and 3 robots.
Forums59
Topics127,981
Posts1,036,180
Members45,904
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
#1436141 Wed Jan 05 2022 01:18 PM
47PUJim Offline OP
I understand the hinge adjustments of the door. I have one problem child. I can’t figure out the adjustment of the most used/abused door, the left side. The door closes but with too much of a slam. I have the other door working fine.
A previous thread says to make sure the door belt line aligns with the cab belt line. That I don’t have. Seems in order to do that I must elongate the height holes to the cowl. Not sure though if that is the answer.
Also I have a “belly” in the middle if the door in the front and back. So the tolerance between the cowl and cab back are way off.
I’m not too sure what should be next. I hate to elongate the hinge holes too much. But it seems the only way to level the belt lines.
My only other thoughts would be bent hinge arms as there was a dent in the cowl from an over extended door. I did replace a section of the floor but never changed the opening measurements.
Am I on the right track with the hinge holes????
47PUJim #1436172 Wed Jan 05 2022 06:23 PM
Unless your door needs to be "twisted" in the opening. How is the front belt line?
As for belly, your door looks good, looks like the over extended cowl repair wasn't pulled out all the way.
47PUJim #1436190 Wed Jan 05 2022 07:47 PM
Can you post pictures of that problem door? If you didn't have the door opening braced when you did the repair work, the opening may be distorted.
If the door opening isn't distorted, then you can increase the height of the rear of the door by moving the bottom of the door back on the lower hinge (the bolts on the door itself.) That will increase the gap at the front lower section. If the belt line doesn't match up at the front, then your only option is to move the door up or down on both hinges (the bolts on the hinge pillar.)
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
47PUJim #1436218 Thu Jan 06 2022 12:03 AM
AD Addict
The OP “47PUJim”, posted pictures under another post. Here is a link. https://www.stovebolt.com/ubbthread...42/boeing-door-pictures.html#Post1436142
The beltline at the rear definitely needs to be raised. I’d like to see a picture of the whole door so you can see the gaps, the front beltline and another showing the rear of the door taken by standing at the rear fender.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
47PUJim #1436336 Thu Jan 06 2022 09:33 PM
47PUJim Offline OP
I posted more pictures. The cowl damage (dent ) really wasn’t deep. Certainly wasn’t as deep as the door gap shows. While I did replace some of the floor, the rocker panel was never disturbed so the door dimension openings shouldn’t have changed. I was careful about that.
The PO did some things that might be coming back to bite me.
Going to work on getting the belt lines to align.
Thanks for your suggestions.
47PUJim #1436344 Thu Jan 06 2022 11:01 PM
Curmudgeon
My 2 pennies.
It's hard to make a door bow out and not have a ripple in the metal that the eye wouldn't see.
Also the door edge (the skin) is not far from the door frame which supports the edge.
Any movement out on the edge would leave a wrinkle and maybe crack the paint.
I took the posted picture and tilted the image 5 degrees then cropped it.
Enlarged to 150% of original. Added a thin red straight line.
The cowl is almost flat at the red line which may indicate a cowl problem.
I think it's common knowledge that when the old hinges rust up, forcing the door to open can bend the cowl in.
Later on, if a dent occurred, it may be hard to tell where the problem lies.
47PUJim #1436348 Thu Jan 06 2022 11:26 PM
There is another thing which happens when a cowl is creased in. The leading edge of the hinge pillar gets twisted inwards while the trailing edge is forced forward. If this is not corrected, the door won't match the cowl, and there will be difficulty in adjusting the door to the door opening.
This can be addressed somewhat by notching the bolt holes in the hinges where they bolt to the hinge pillar.
47PUJim #1436371 Fri Jan 07 2022 01:20 AM
Curmudgeon
This is almost hard to believe but I've seen it done by a body man.
A piece of wood in the door jam and push in on the door to force hinge pillar back in place.
I don't have the skill to do this myself without causing other damage.
This was done back in the days when the AD was used as a truck.
The cowl appearance, beltline and gaps at the door edge didn't matter as much.
As long as the door shuts good and didn't pop open by itself.
buoymaker #1436372 Fri Jan 07 2022 01:24 AM
I've heard of that 2x4 method before. My dad said it was done on the '54 Chevy Station Wagon we had when i was a kid.
But if the replacement cowl was welded in with the door pillar tweaked, it would be hard to stretch that enough to work. It might kink the inner cowl panel instead.
47PUJim #1436379 Fri Jan 07 2022 03:09 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
I have personally done the 2X4 repair a couple of times back in the late ‘60s early ‘70s. I’m not a body man and never would claim to be but I was strapped for cash and I needed the door to close properly. I worked remarkably well.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Page 1 of 2 1 2
Moderated by  48bigtrucks
