We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
14 members (Hambone, buoymaker, Ga92009, Goach2, fixite7, D B Cooper, 2 invisible),
91
robots. |
Key:
Admin,
Mod
Forums60
Topics127,511
Posts1,032,073
Members45,794
Most Online1,229 Jan 21st, 2020
 3600 lowering
OP
Yes I've searched. Not a ton but closer than a 1/2. Want to lower 3 inches without drop axle. Can it be done. Pics please. Thanks for any help. My pics are to big before anyone asks. I'm not computer savvy. Soory.
 Re: 3600 lowering
6 lug wheels are half ton, 8 lug are 3/4 ton with single rear wheels for ‘47.2 and later.
Ed
 Re: 3600 lowering
OP
Understand that Ed I know I have a 3/4 ton. But wanting to lower about 3 inches. I have considered converting to dually but unsure how this can Be done.
 Re: 3600 lowering
Trucks with higher weight capacity than a 1/2 ton are a lot more difficult to hotrod, primarily because there's just not enough demand for the parts needed to alter them. A truck in a town near my place pretty obviously began life as a mid-1980's 1 ton box truck like the ones Hertz and U-Haul rent. Over the past several month I've watched it get transformed into a "pickup" with a stepside bed about 10 feet long lowered, and equipped with "super single" style ultra-wide wheels and tires. Personally, I think it's butt-ugly, but someone has gone to a great deal of work and expense to make it look that way!
You might want to consider air bags instead of springs to get the ride height you're looking for. Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
WAG MORE- - - - - -BARK LESS!
 Re: 3600 lowering
Unrepentant VW Lover
Jerry -- Can't he just remove a few spring leaves?
John Cisgendered heteronormative aggressor perpetrating problematic toxic ideas of Chevrolet normativity  '49 Chevrolet 3804
 Re: 3600 lowering
The axles will bottom out against the frame- - - -makes for a very rough ride. Of course, even with a more sophisticated lowering method, some major frame modifications will be required, "C-notching" or something similar. Jerry
