The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Thinking again ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (D B Cooper, 3800GUY, DaveV, John Dlugos, NJC, 1 invisible), 62 guests, and 6 robots.
Forums60
Topics127,583
Posts1,032,707
Members45,812
Most Online1,229
Jan 21st, 2020
Image Posting Policy
250 valve adjustment
#1435948 Tue Jan 04 2022 02:11 AM
7
What is the best way to adjust the valves on a 250 chevy. I am rebuilding the engine. I have done several 350s but not the 250
Re: 250 valve adjustment
79broncoowner #1435961 Tue Jan 04 2022 03:13 AM
Does it have ‘juice’ lifters?
Ed
79broncoowner #1435964 Tue Jan 04 2022 03:19 AM
250's have hydraulic lifters, so they're adjusted just like a small block V8. Get each cylinder to top dead center on the compression stroke, gently take the slack out of the valve train by spinning the pushrod as you tighten the adjusting nut, and add an additional 3/4-1 turn of the adjusting nut after the slack is taken up. Adjust both valves, then move on to the next cylinder in the firing order. I use the companion cylinder valve adjustment method, but nobody else seems to be interested in doing it that way.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
79broncoowner #1436000 Tue Jan 04 2022 02:58 PM
If the lifters are dry or have been setting a long time, the feel for zero lash is a littler harder to find. There is little resistance in the lifter when not oil filled, it can be done, just takes a little more care.
Moderated by  Woogeroo
