The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Shaffer's1950, Rsqwhite, d49chevy, homer52, 2ManyTrucks), 88 guests, and 3 robots.
Forums60
Topics127,485
Posts1,031,819
Members45,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Resize a stock steering wheel
latroca52 #1435190 Thu Dec 30 2021 06:30 AM
Thanks for all the feedback on this topic I will do some more research on another steering wheel that will work well with my stock steering column.
This is no longer fun
latroca52 #1435291 Fri Dec 31 2021 01:23 AM
Curmudgeon
FYI:
I think Classic Truck Magazine sold out to Motor Trend (the link I posted above).
latroca52 #1437152 Thu Jan 13 2022 09:52 PM
I found a wheel from a Fiero at Pick your Part. It has 3 spokes similar to the original wheel and has a slight dish to it. I replaced the horn cap with one from a mid 70's Camaro and used a bowtie emblem in the center. Also installed the stock turn signal cancel plate and it works well.
Fred
latroca52 #1437548 Sun Jan 16 2022 11:15 PM
I saw a thread elsewhere where a 1960-66 C10 steering wheel that was “shrunk”. The work was more than I would want to put into a project, but the result looked nice. The diameter of the wheel was made smaller by cutting the spokes shorter and then re-welding them to the hub. Sections were removed from the outer ring and then the pieces that remained were placed in a jig to align them so they could be welded together again into a smaller ring. Most of the original wheel outer plastic (or whatever polymer it is) was retained but the gaps where the welding occurred were filled with an epoxy much like JB weld and shaped to resemble the original wheel material. All done and painted it looked nice but not what my time is worth. Just saying.
A smaller diameter aftermarket wheel is worth the money IMO. I will say that the aftermarket wheels do a poor job at helping the average Joe figure out how to make the horn work again when installing a new steering wheel. That’s been my stalling point when I think about installing the new wheel I still have in the. I’d on the shelf.
latroca52 #1437551 Sun Jan 16 2022 11:59 PM
Curmudgeon
The link is on page one if you want to use it for reference.
buoymaker #1437554 Mon Jan 17 2022 12:07 AM
Yes indeed. I passed right by that link as I scanned the replies.
Looks to be the same set of pics I saw some time ago. Good reference!
Well, my description pales to that thread with pics.
latroca52 #1440226 Sun Feb 06 2022 01:41 PM
Itroca 52 Sure you can re-size a steering wheel,get one that needs help,cut it down to your dimensions weld metal frame. Make a mold the shape you want pour in epoxy,file and sand,paint. Not rocket science !!
Page 2 of 2 1 2
Moderated by  KCMongo
