The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (DavidBraley, KEVINSKI, Justhorsenround, Bill Trotter, 55shaker, 1 invisible), 81 guests, and 3 robots.
Forums60
Topics127,506
Posts1,032,027
Members45,793
Most Online1,229
Jan 21st, 2020
Image Posting Policy
S10 rear axle
#1435093 Wed Dec 29 2021 07:13 PM
Jrp Offline OP
Moderated
Hello folks
I have a 52 3100 that is getting a ls swap and I’m on the hunt for a rear axle. I have found a 90 or 91 s10 rear axle that is out of a 4x4. It’s not a zr2. Anybody know if this would work? Truck will have air ride. I have read where some say it will and some say to narrow. Just trying to find out all I can before spending the cash.
Thanks for any help/ info
Re: S10 rear axle
Jrp #1435106 Wed Dec 29 2021 08:27 PM
Curmudgeon
Do some measuring before you buy. People can make mistakes.
http://chevy.oldcarmanualproject.com/chevyresto/52060.html
This may not be 100% correct:
Measure from flange (what the rim bolts to) to flange.
My notes says 1947 to 1955 first, 60 to 62 inches.
Compare with the donor.
Re: S10 rear axle
Jrp #1435114 Wed Dec 29 2021 09:06 PM
S10 widths are: 2wd 54.5", 4wd 59", ZR2 63"
4wd comes closest. In my 1952 3100 I used a rear end from a 1969 1/2 ton Chevy pickup and it was 1 inch wider than the 1952, which worked fine (1/2 inch wider per side).
According to GM records, the 1952 Chevy should have been 61". 2 inches more narrow can make more difference than you might expect. It pulls each wheel 1 inch closer to the bed side (that gets tough if you're running wider tires than the original 600x16). Good luck.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: S10 rear axle
Jrp #1435160 Thu Dec 30 2021 02:34 AM
Jon, do you measure the width of any rear axle from backplate to backplate? The manual drawing shows 61” measured from center of tire to center of tire.
Also, somewhere on this site I saw a list of possible donor rear axles and their widths. Would you happen to know where I can find that list? Thanks
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Re: S10 rear axle
Jrp #1435169 Thu Dec 30 2021 03:38 AM
A more realistic measurement is wheel mounting surface(wms) to wms, although does not correspond to any published info.
Ed
Re: S10 rear axle
Jrp #1435173 Thu Dec 30 2021 03:51 AM
Chuck, I use what makes the most sense at the time and go with that (but be constant between the 2 rear ends, of course). In this case the rear end I wanted had both wheels and tires still on it and there was enough room for me to crawl under and work a tape measure, so there was very little guesswork. In other cases where I've done rear end swaps I've used some different approaches. Remember also some wheel inset measurements are different...
I've seen that list, but I can't recall if I saw it on this site or on another. But yes, somebody somewhere did have a list like that.
Jon
Re: S10 rear axle
Jrp #1435341 Fri Dec 31 2021 10:01 AM
Ed, that info is out there because I used it to install the nova rear end in my 54. But after 30 years I don't know where. Maybe this. https://www.hemmings.com/partslocator/axles.html
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Moderated by  SWEET
