We are still asking: What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Has anyone tried to put in a 6x9 speaker behind the dash of a 55 1st series 3100 without using a plate attached to the radio?. I have a RetroSound radio and don’t want to hang speakers in the kick panels or up in the dash on either side of the cab.
I don't have your year of truck but it appears that the plate is the most logical option. I don't know if you need a 6x9 but a lot of more modern Ford products used a speaker that was, I think 6x8.
Judging by the length of the RetroSound shafts (tuner, volume etc.), they are not long enough to mount a speaker panel. Regardless, the RetroSound shafts are not strong enough and would probably break from the weight. You will have to make your own speaker brackets. On the left side is an dash brace going to the firewall. GM used this brace to attach a mounting bracket. On the right side, unfortunately, I have no idea.
One thing about a cowl vent. If open and rain happens, your radio and speaker can get wet. I would fabricate a shield of some kind for protection.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
