The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Remember old days
Remember
The old Bulletin Board?
click to enter
The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to
The Wayback Machine.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (KEVINSKI, 59 fleet, JW51, J Lucas, Curt B., 1 invisible), 84 guests, and 3 robots.
Forums59
Topics128,108
Posts1,037,361
Members45,936
Most Online1,229
Jan 21st, 2020
#1435010 Wed Dec 29 2021 01:05 AM
MarkWH Offline OP
Has anyone tried to put in a 6x9 speaker behind the dash of a 55 1st series 3100 without using a plate attached to the radio?. I have a RetroSound radio and don’t want to hang speakers in the kick panels or up in the dash on either side of the cab.
Mark
M. Hayden
I don't have your year of truck but it appears that the plate is the most logical option. I don't know if you need a 6x9 but a lot of more modern Ford products used a speaker that was, I think 6x8.
MarkWH Offline OP
Thanks. I have 1955 1st series. Might start looking into fab’ing a plate that attaches to the radio mounting bracketry
M. Hayden
Curmudgeon
Judging by the length of the RetroSound shafts (tuner, volume etc.), they are not long enough to mount a speaker panel.
Regardless, the RetroSound shafts are not strong enough and would probably break from the weight.
You will have to make your own speaker brackets.
On the left side is an dash brace going to the firewall.
GM used this brace to attach a mounting bracket.
On the right side, unfortunately, I have no idea.
One thing about a cowl vent. If open and rain happens, your radio and speaker can get wet.
I would fabricate a shield of some kind for protection.
Moderated by  truckernix
