We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,470
Posts1,031,724
Members45,787
Most Online1,229 Jan 21st, 2020
 Odometer issue. Repairable?
OP
Hi.
There is not 1 digit readable on my odometer. Is this something i can take out easily? Can i change the gauge, rollers or decals myself? Who has some experience in this.
 Re: Odometer issue. Repairable?
Ex Hall Monitor
I've not tried rebuilding one myself. The classic speedo rebuilder I use in Cushman Speedometer in Wichita KS. https://cushmanspeedometer.com/
Save a life, adopt a senior shelter pet. The three main causes of blindness: Cataracts, Politics, Religion. Let's go Jared! Name your dog Naked so you can walk Naked in the park.
OP
Additional info. I live in the Netherlands. So sending it somewhere is a bit more difficult
Ex Hall Monitor
Oops. I see that now. Hopefully someone with personal experience rebuilding one will be along to help. Good luck.
You can buy decals and rebuild it your self. Just takes patience and follow directions closely. Harold https://oldchevytrucks.com/1934-1946/decals.html
Harold Is a restoration ever finished?
Professional procrastinator
It has been a while but I did plenty of them when I was a young man. The trick is to go slow and carefully. Document what you are taking apart so you will know exactly how it goes back together. You will need to identify at least one number on each wheel so you can position the decal strip properly otherwise when the 10th's wheel gets to 6 it might rotate the 1's wheel and so forth.
1946 Chevy 3/4T panel 1947.2 GMC 1/2T panel 1947.2 GMC 1/2T long bed 1948 GMC 1/2T pick-up
I have rebuilt one and it isn’t terribly difficult. I also used a reproduction decal kit and it turned out well. The worst part is taking off the speedometer needle off its pivot point. That is the absolute worst part because of the VERY fragile nature of that needle on the shaft. After that, go slowly, take pictures, and you’ll have it back together in no time. Here is a sort of “before and after” of two speedos I had. Both were in this kind of rough shape when I started. You can do it. This was the very first speedo I had rebuilt and it went fine. Just be CAREFUL taking off the needle. These old chevs\GMCs aren’t sitting around in farmers’ fields in the Netherlands like they are in Canada and the US! I had 3 speedometers as backups just to be sure I had enough parts, in case I broke something. https://photos.app.goo.gl/YEOFa2AbSgJQURDt2
In the Stovebolt Gallery [ stovebolt.com] More pictures here [ photos.app.goo.gl] 1951 GMC 9430 1 ton dually—-Shiny! 1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny 1972 Chevrolet C20- Rusty- the puzzle box lid for the C10. 1950 Chevrolet 1300- in progress to shiny. 1962 AMC Rambler American- my wife’s Parts trucks- 1951 GMC 9300 1951-GMC 9430 1951- Chevrolet 1300
The odometers of a 1945 chevy aren't too hard to disasamble. Just make enough pictures of your disasambly so you know where everything goes. Unfortunately Prinstruckshop doesn't have te decals. So you probably need to get it shipped from the US.
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Use a common eating fork to remove the speedo needle.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily” ‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
OP
Thanks all for the valuable information. I will go on the hunt for the decals.
Update: decals ordered. Now wait for them to arrive in the Netherlands
If the decals don’t work out for you…
I purchased a new assembly of numbers when I refurbished the speedo head on my ‘46. It’s held immobile at all zeros with a plastic clip which you pull out AFTER you install the new assembly. If you remove the plastic clip before the assembly is securely in the head, you spend the rest of your life getting it reset back to all zeros (don’t ask how I know that).
I’m of average mechanical skill and am very pleased with the results. Greg
I posted free templates for printing these decals on waterslide decal paper. Here's a link: https://tinyurl.com/yc54nsua Man it would be nice if we had Tech Tips or some sort of repository for stuff like this. The last odometer I re-did looks just like new.
Jon
1952 1/2 ton with 1959 235 T5 with 3.07 rear end
I purchased a new assembly of numbers Greg, Where didyou buy the odometer unit? Harold
Jim Carter has the whole odometer unit to put into your speedo. Link [ oldchevytrucks.com]
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
im Carter has the whole odometer unit to put into your speedo. Link [oldchevytrucks.com] That unit is for the 1937-1939 & 1947-1954 Odometer. JC says this will not work in 1940-1946 trucks. Harold
That unit is for the 1937-1939 & 1947-1954 Odometer. JC says this will not work in 1940-1946 trucks. Harold Interesting that there's a gap in the years. I didn't notice that.
