We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,583
Posts1,032,706
Members45,812
Most Online1,229 Jan 21st, 2020
 Re: Spark plugs for a 235 engine 1954 Chevrolet
AC-R45S is the correct plug for that engine. The s is for extended tip. It is a better plug then the recest tip originally used. In the late 50,s the extended tip plug was invented & most auto makers went to them. They cannot be used on flat head engines though. The R is for resistor plugs. George
1972 Chevy c10 Cheyenne Super
Curmudgeon
The stock spark plug for a 235 was AC-44 for regular (non-Ethanol) gasoline.
Today: AC-R43S = colder range spark plug AC-R45S = hotter range spark plug
Which one is best for your engine depends on which gasoline type you plan to run. Ethanol generates more heat than non-Ethanol.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
It seems that I read somewhere that you should not use the R45S plugs in a 235 because they extend farther than the old R44 and can burn a hole in the piston. But they’re okay for the 216. Those are what I am using in my 216. Anyone care to shine a little light on the subject and either confirm or dispel?
I invest my money in precious metals, mostly rust!
It seems that I read somewhere that you should not use the R45S plugs in a 235 because they extend farther than the old R44 and can burn a hole in the piston. But they’re okay for the 216. Those are what I am using in my 216. Anyone care to shine a little light on the subject and either confirm or dispel? It sounds like the dumbest thing I ever heard.
My 55.2 3100 235, calls for AC R43.
Brian 1955.2 3100 Truck
I just bought a set of Ac delco r45 spark plugs to replace the set of autolite plugs in my 235
This is no longer fun
I chose the R43's, most of my driving is with the engine running high cruising RPM's, that's why I went with the colder plug.
I've been running # 7 - ACDelco for years w/ langdon mini HEI. Plugs stay very clean.
BC 1960 Chevy C10 driver 261 T5 3.73 dana 44 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022
