We are still asking: What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
What 6 cylinder is in my latest project ‘66? I’ve searched quite a bit and cannot find this block casting number in anyone’s list. The identification code leads me to believe it’s a 1971 year but there’s a lot I cannot find on it as well.
Block casting # 399425
Engine ID Code- F0604CAB Engine VIN- 11N589180
What vehicle was Suffix Code “CAB”? Is this a 250 or a 292?
230 and 250 engines use the same block. The cubic inch difference is in the crankshaft stroke. 292 engines have a taller side cover, and the motor mounts are offset about 3" from side to side. If you can get a borescope into a cylinder through a spark plug hole, look at the top of a piston. 230 engines have flat top pistons. 250's have dish tops. In the mid-1960's there was also a 194 cubic inch six used in the sub-compact Chevy II that looks similar to a 230/250. Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson
