The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Bill Marlow, DES57, 1955first6500, dunfire, crenwelge, 47 BOMBER), 85 guests, and 3 robots.
Forums60
Topics127,472
Posts1,031,732
Members45,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Mandatory for engine to sit level?
#1426807 Thu Oct 14 2021 06:47 AM
I've got a Buick 350 LT1, fuel injected, in my '50 3100. The engine sits level side to side but is an inch or two tilted down transmission side. Because of the engine mounts needing to be raised to accommodate the ac compressor, I don't have enough clearance on the floor to raise the transmission to make fore and aft level. With carburetion, it is necessary for the bowls and float to work properly...maybe not a concern for fuel injection?
Re: Mandatory for engine to sit level?
Rocket man #1426813 Thu Oct 14 2021 12:18 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Tail down is pretty normal. There is a desired angle that someone will post soon. Having to cut and modify the transmission tunnel is normal too.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Rocket man #1426819 Thu Oct 14 2021 01:27 PM
I agree, most tilt down in the back, up to 8 degrees.
Rocket man #1426820 Thu Oct 14 2021 01:28 PM
3 to 5 degrees down for the engine and trans. is normal. Most intake manifolds are machined to keep the carb. level.
Ed
Rocket man #1426822 Thu Oct 14 2021 01:34 PM
Before I removed my 235, I measured the pitch angle. It was 5 degrees tail down with the chassis level. Since you're using an injected engine, probably not a big deal how much as long as your driveshaft angles are in the good.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Rocket man #1426834 Thu Oct 14 2021 03:13 PM
U-joint working angles are 1/2 to 3 degrees, more or less under ideal conditions. Thats tail shaft to driveshaft, and driveshaft to pinion gear. As long as the oil pickup is still under oil, and the u-joints are happy, it will work. Setting level doesn't mean much when roads have hills and turns, means even less with fuel injection, just look at how some boat motors are mounted !
Rocket man #1426998 Sat Oct 16 2021 03:37 AM
Just make sure that your engine/transmission drop angle is parallel to your pinion angle within a degree or two to keep the u-joints happy.
Rocket man #1427051 Sun Oct 17 2021 02:43 AM
If you get no driveshaft vibration, leave it alone. Back in carburetor days they had cars in San Fransisco that seemed to do quite well on really steep angles. Ford vans were not only tilted but also offset to the right.
Evan
Rocket man #1429411 Sat Nov 06 2021 11:15 PM
Rocket man Your in the range,make sure u-joints are happy and go for it if no noise you've got it !! It will show up if you go to pull on something like a stuck vehicle.
Rocket man #1433734 Thu Dec 16 2021 03:54 PM
V
Always was told about 3 degrees....
Page 1 of 2 1 2
Moderated by  KCMongo
