The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Thinking again ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Bill Hanlon, 68ironhead, JW51, d49chevy, 2 invisible), 79 guests, and 3 robots.
Forums60
Topics127,584
Posts1,032,712
Members45,812
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Assembly lube
lumbersawyer #1432964 Fri Dec 10 2021 12:22 AM
https://www.summitracing.com/parts/hrs-99005
https://www.summitracing.com/parts/cro-86096
https://www.summitracing.com/parts/red-80312
For camshafts, you want a specific type of grease like I linked above, the liquid lubes will run off and leave most of it in the oil pan. The true cam grease is a black moly paste or grease. The Redline assembly lube I linked is good for everything else. If the engine is going to be started right away, as in a day or so of final assembly, then liquid assembly lube will be fine. If it is going to set, then be sure to use a paste and limit the amount you rotate it once assembled. Every rotation wipes the lobes clean.
Re: Assembly lube
lumbersawyer #1432983 Fri Dec 10 2021 04:38 AM
lumbersawer Used to use EOS GM cam break-in lube when it left went to just oil gonna pressure prime anyway,since this zinc stink has come along now need to deal with that. Read where you need to mix the zinc additive in your oil to be sure it's available during break-in. Or use a zinc base break-in oil. On hi-revers with a roller cam we use zinc 10w30 for 2000 rpm break-in run. Could use 15w40 with zinc in it like OTR truckers use.
Re: Assembly lube
lumbersawyer #1433028 Fri Dec 10 2021 04:32 PM
I’ve heard of folks using Lucas oil as assembly lube. Anyone have experience with that?
Re: Assembly lube
lumbersawyer #1433172 Sat Dec 11 2021 07:05 PM
Lucas has bunches of different products. Which one? I believe they might make one specifically for engine assembly. If you're referring to the engine oil additive- - - -no!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Re: Assembly lube
Hotrod Lincoln #1433283 Sun Dec 12 2021 03:54 PM
Yep I’ve heard of folks using the thick oil additive.
Re: Assembly lube
lumbersawyer #1433287 Sun Dec 12 2021 04:20 PM
Unless it's a lot different from STP (which I doubt) it would be hard to persuade me to do that.
Kris Kristofferson
Re: Assembly lube
Hotrod Lincoln #1433398 Mon Dec 13 2021 04:42 PM
There’s a “project farm” video where he compares New STP, Old STP, and modern 5w-30 in several tests. Both the old and new STP had shockingly low levels of zinc, even just compared to the 5w-30.
Wonder if that aspect contributed to your failures with STP?
Re: Assembly lube
lumbersawyer #1433401 Mon Dec 13 2021 04:52 PM
That's possible. My experience with oil-related problems with engines I assembled with STP was back in the late 1960's and early 70's before zinc additives in motor oil were an issue. Just to convince myself what I was experiencing was a fluke, I built one more engine (an air cooled Volkswagen) with STP and it had chronic low oil pressure. I sold the car to my brother, and he wrecked it before we got a chance to do an autopsy on the engine problem. Since then I've used a dedicated assembly lube.
Kris Kristofferson
Re: Assembly lube
lumbersawyer #1433403 Mon Dec 13 2021 05:09 PM
https://youtu.be/ypQwgm1H2NU Here is some else to watch.
Re: Assembly lube
lumbersawyer #1433517 Tue Dec 14 2021 05:23 PM
lumbersawyer left info went in clouds
Page 2 of 3 1 2 3
Moderated by  Woogeroo
