The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Rsqwhite, Ridgeback, justmike, Dakotabolt, Shakey61), 113 guests, and 2 robots.
Forums60
Topics127,470
Posts1,031,724
Members45,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Picture wanted of the wood sides
#1432292 Sat Dec 04 2021 07:10 AM
Robby45 Offline OP
I would like to add wooden planks on the side of the bed. But how you fix the vertical ones on the bed? I have no holes orso to fix them though. If i stick one in from the top if falls out in the bottom 😁
Who has a picture where i can see the inside of the bed and how its fixed?
Re: Picture wanted of the wood sides
Robby45 #1432303 Sat Dec 04 2021 01:55 PM
Crusty Old Sarge
Normally the vertical slats drop into the bed pockets at the corners.
Craig
Come, Bleed or Blister something has got to give!!!
59' Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
TUTS 59 #1432304 Sat Dec 04 2021 02:29 PM
AD Addict
The horizontal slats keep the upright posts (slats) from falling thru.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Phak1 #1432308 Sat Dec 04 2021 02:57 PM
Robby45 Offline OP
Aaah ok. I was wondering indeed. Because if you put a vertical slat in the come out at the bottom haha
So the horizontal planks will rest on the side of the bed?
Robby45 #1432310 Sat Dec 04 2021 03:14 PM
Robby I also made a wooden rack on the sides. For the sides i used wood slightly bigger than the hole itself, after that I shaved a bit of the underside so that it goes in the holes. The wooden beams i used were from the Karwei. If you want i can give you the dimensions and detailed photos of the rack.
Robby45 #1432311 Sat Dec 04 2021 03:18 PM
Robby45 Offline OP
Thanks. Will do that! Did you use a special kind of wood?
Robby45 #1432315 Sat Dec 04 2021 03:25 PM
I don't know what kind of wood it is. It think it is sparrenhout (bouwhout).
Robby45 #1432323 Sat Dec 04 2021 04:22 PM
I just used screws on the inside of the pockets.
Robby45 #1432388 Sun Dec 05 2021 07:13 AM
The AD trucks came from the factory with sheet metal stops welded in part way down the stake pocket. My bed also had thru holes front to back just above the bottom of the stop.
But the stops in mine had been beaten out by whatever they put in the pockets and there were holes in the aprons below the stake pockets. All that is getting fixed, including new stops that I had fabricated.
The first pic shows one of the stops sitting above where it goes in the stake pocket, and the holes thru both the stake pocket and the stop for a thru-bolt.
The second pic shows my dimension sketch for fabbing new stops. An ex-employee worked for a company that has a 30 ton press brake, and offered to bend them up for me.
Pic #3 is the new stops painted and ready to go in.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Robby45 #1434345 Wed Dec 22 2021 02:56 AM
I used the same method as Hookalatch, with a countersunk head wood screw in the side of the pocket, then painted it the same colour as the sides. Virtually invisible.
Page 1 of 2 1 2
