We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,512
Posts1,032,075
Members45,794
Most Online1,229 Jan 21st, 2020
 '62 C20 replacing bed; also windshield question
OP
Moderated
The old bed was completely rotted on my truck. Found some old wood at the farm that has been protected (it has a rough-sawn appearance) and it's 1" thick. I've read the original bed wood was 1" thick, which was actually 3/4". I cut the first board and trimmed it to 3/4" thick. I placed it in the slot against the body side, and noticed my chrome trim on the outside doesn't follow a straight line now. The door trim is lower than the bed trim. Should the wood be thinner than 3/4"? I'm wondering if there's some other problem. There's lots of discussions about what kind of wood to use but without a bed template, I'm just doing a lot of guessing about the details of replacing the wood. I will have to drill new holes in the metal to accommodate my 6" wide planks (I'm not going to reproduce that crazy original bed pattern).
also what will take the smoky appearance off the bottom of the inside of my windshield? I've already cleaned and scrubbed all glass with vinegar/lemon juice/Dawn soap. Also used baking soda on it.
david tate
 Re: '62 C20 replacing bed; also windshield question
Your question is better answered in Making a Stovebolt Bed forum. Mar-K is a great resource for bed parts and information. Also this site has some good info. Link [ gmcpauls.com] Your windshield should be laminated glass and the plastic lamination between interior and exterior may be discolored. There's probably no solution except to replace it if that's the case.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
