The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (32vsnake, 68ironhead, Donf, DennisM, ‘37ChevyPU, 1 invisible), 114 guests, and 3 robots.
Forums60
Topics125,462
Posts1,013,063
Members45,239
Most Online1,229
Jan 21st, 2020
Image Posting Policy
windlace, cab interior at door opening
#1431085 Tue Nov 23 2021 07:48 PM
I have read past posts on this and they were helpful. If I understood right, you slide the windlace through the track at the front and rear of the door opening. But you manually push it into the track across the top, i.e. not slide it across the top. Am I understanding right? If so, can you start the feed at the front and rear from the gap at the top?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
1950 Studebaker Starlight Coupe
Re: windlace, cab interior at door opening
Mike Burns #1431087 Tue Nov 23 2021 08:06 PM
No, according to the service manual, you slide the windlace into the upper track first from the back, starting at a notch in the weatherstrip (which would leave the front and rear loose, then feed the front and rear sections into the channels from the top. The manual also says to use lubricant on both the channel and the weatherstrip.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Mike Burns #1431113 Tue Nov 23 2021 11:27 PM
Have had good luck using the original white Go-Jo as a lubricant. Slippery as snot and immediately cleans up with water when done.
Evan
Mike Burns #1431116 Tue Nov 23 2021 11:48 PM
At the factory the windlace was retained by hammer or mallet blows every 6 or 8 inches denting the track. You will need to identify and open up those dents or you won't be able to slide the new one in. Take a one or two inch section of the old windlace (or new if you have enough) and slide it along the track to identify any tight areas.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Moderated by  ndkid275
