Come all who are near!
Southern Bolters Jamboree
this weekend
June 2-3
in
Tennessee
Details here
Still plays with trucks
Things are happening all over. Missing anything? Check in the The Side Lot and see.
Searching the Site
2023 Old Truck Calendars
Second one
Sweet-looking old Stovebolts
2023 Stovebolt Calendars
Check for details!
3 members (Fox, Steelonsteel, Rich'sToys), 220 guests, and 3 robots.
Forums64
Topics129,521
Posts1,068,120
Members46,944
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
Thank you.
I am now planning on using formica rather than cardboard for the backing of the side panels and door panels on my 1954 Suburban. You have confirmed my strategy.
The original-style card-board (backing) deformed from moisture.
Do you have a suggestion for the type of adhesive I could/should use to attach the vinyl material to the formica panels?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
“Grease Monkey” “Former herder of cats”
Just plain old spray adhesive (3M Brand) you can get at your FLAPS. Find center point front to back. Spray a 2-3” strip down the middle front to back. Find center on your vinyl and spray a 2-3” strip down the middle front to back. Carefully mate the surface working slowly. Then you can work in 4-5” strips from center to outer edge until reaching the farthest point + 1/2” to turn over the edge. Then do the same from center to the other edge. Pull and straighten wrinkles as you go. If you mess up you can use steam to reactivate the adhesive. Slow and steady is the name of the game. Good luck.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
The FLAPS has some good adhesive and some not so good (fails early) adhesive. I'll try to remember to get the number of the good 3M stuff when I get home.
3M77 is the mild adhesive
3M90 is the strong adhesive
Chuck
Page 2 of 2 1 2
Moderated by  ndkid275, Phak1
