We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,490
Posts1,031,882
Members45,791
Most Online1,229 Jan 21st, 2020
 windlace, cab interior at door opening
OP
I have read past posts on this and they were helpful. If I understood right, you slide the windlace through the track at the front and rear of the door opening. But you manually push it into the track across the top, i.e. not slide it across the top. Am I understanding right? If so, can you start the feed at the front and rear from the gap at the top?
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1953 Ford Victoria 1950 Studebaker Starlight Coupe
 Re: windlace, cab interior at door opening
No, according to the service manual, you slide the windlace into the upper track first from the back, starting at a notch in the weatherstrip (which would leave the front and rear loose, then feed the front and rear sections into the channels from the top. The manual also says to use lubricant on both the channel and the weatherstrip.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
Have had good luck using the original white Go-Jo as a lubricant. Slippery as snot and immediately cleans up with water when done.
Evan
At the factory the windlace was retained by hammer or mallet blows every 6 or 8 inches denting the track. You will need to identify and open up those dents or you won't be able to slide the new one in. Take a one or two inch section of the old windlace (or new if you have enough) and slide it along the track to identify any tight areas. Kent
