What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
1 members (Fox),
92
robots. |
Key:
Admin,
Mod
Forums59
Topics128,567
Posts1,041,570
Members46,048
Most Online1,229 Jan 21st, 2020
OP
I need to replace the seal behind the pinion on my 1ton. I'm sure the nut is a 1-5/8 inch nut but my socket will not go inside the yoke. I have searched every parts house around to find a thinner socket with no luck! Any help would be appreciated!
I had to take a brand new socket to the grinder and shave some off until it fit. Didnt take too much. John
1949 gmc 1-ton
Yes, I ground one down years ago. George
1972 Chevy c10 Cheyenne Super
OP
Thanks guys! I measured the inside of the yoke and it's 2.19 and the socket is 2.20. to the lathe I go!
Sir Searchalot
Thanks guys! I measured the inside of the yoke and it's 2.19 and the socket is 2.20. to the lathe I go! for .005 a side, I would just burr the yoke. Then the socket won't rust.
Watch out for careful drivers!!! I'm away on an ego trip. Will be back on Feb 30. I'm not an Auto Mechanic, but I play one on TV. I charge $0.02 for every opinion and I take Paypal. Plan B is always better than plan A, by definition. "We have no time for comment, every man will make his own. LET IT BE MADE WITH POWDER AND BALL!!!" I recommend invoking MIL-T-FP41c when machining and fabricating I used to think beer was bad for me, so I gave up thinking. Sometimes no nonsense makes sense, in a sense. You can't teach a new dog old tricks. Honk if you're Amish
Mixed Up
Sockets are pretty hard material. I would just chuck it up in a lathe and use a 90* hand grinder to get the .010 off while it is spinning. Then wipe the lathe back down.
Don
Mine is not purdy. I just held it up to a bench grinder & turned it slowly by hand. George
Sockets cut fine on a lathe. You don't need a carbide tool, HSS will do the job. We have sockets for removing body trim nuts that have the bevel turned off since the trim nuts are so thin a standard socket doesn't fit far enough onto the nut. Tools are tough but not hard as they would crack/shatter if too hard.
Evan
OP
I turned 2 thousands off the diameter of the socket on the lathe and it fits good. Now if I can get enough leverage to break it loose! Holy crap this nut is tight!!
Now if I can get enough leverage to break it loose! Holy crap this nut is tight!! The torque spec for a 1 ton pinion nut is 160-280 ft-lb. So either break out the impact wrench or put gravity to work and stick a jack under the end of the breaker bar.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
