The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (AlwayswrenchN), 78 guests, and 3 robots.
Forums59
Topics128,568
Posts1,041,571
Members46,048
Most Online1,229
Jan 21st, 2020
Page 2 of 3 1 2 3
1933 Chevy trucks used the hood, fenders, and a painted version of the 1932 passenger car grille shell. I suspect your truck is a '33. Look at some websearch images of '31, '32, and '33 Chevy trucks. I think the mystery will be solved. Neat looking truck. Any I.D. tags anywhere?
Mike
Direct email ml.russell1936@gmail.com
Either way. Very cool to get a truck that has been untouched for this many decades!
The previous owner was pretty convinced it's a 31. But.. I'm not versed in real early pickups. Just learning! There's a tag, but not much left on it. Someone just HAD to have a hole there! I'll do some digging around, see what I can find. Hard to tell much difference between 31-33. I've read fenders, cowls, and hoods are different, but I can't much tell from pics. The fenders I got with the 30' frame look very similar to the fenders on the 31'.
I would like to find front rims to match the rear. Not a huge fan of the spokes. All in due time.
The "1CB.." on the serial number plate indicates Flint, 1933 1/2 ton truck. Clearly the rear axle is from a larger truck but it is curious that a big truck would come with wire spoke front wheels. Perhaps the truck is a 1/2 ton that had the rear axle switched? More investigation needed regarding the the front axle, frame size, etc.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Dan Beluscak Always buy em so you can sleep in em for a few days LOL !!
Dan Beluscak Always buy em so you can sleep in em LOL important rule of old truck buying !!!
1935 1.5 ton military
I think you did great! Almost as pretty as my '35 (Qubie is prettier 'cause she's mine). I keep my mechanical brakes adjusted properly and I generally have no problem driving and stopping here in the WNC mountains. There was one time tho; I had 980 pounds of broken concrete blocks in the back that I was taking to the landfill. I was on a steep downhill stretch with a T intersection at the bottom, and if I had not been in the proper (low) gear or if I had a weak right leg, I would have sailed through that stop and off the road. As long as you're empty and drive sane, you should have no problems. If you have a load, be extra careful.
My '35 came with a hand crank. It stores under the seat along with the jack, which uses a different crank.
'35 1.5 ton military
Dan,
THANK YOU so much! Your "not perfect" pictures are a huge help for one that has Nothing.
Evan
Evan
Grandpa's beer hauling 1935 Chevy tractor-trailer rigs got retrofitted with a vacuum booster for the original mechanical brake system, a cylinder that basically made the driver's right leg stronger- - - -still had no trailer brakes, however! They hauled bottles and kegs from Milwaukee and St. Louis to Nashville in the mid-1930's. Sadly, no pictures of those rigs survived!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
Moderated
I love this old buggy. I have a '41 2-ton with a 1960 261 engine.
Page 2 of 3 1 2 3
Moderated by  69Cuda, Grigg
