Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
13 members (Gdads51, dougs, festerhairball, Danielbolt, Djg, Hotrod Lincoln), 675 guests, and 5 robots.
The Zone
Forums65
Topics123,414
Posts999,164
Members47,264
Most Online1,229
Jan 21st, 2020
#1429026 Wed Nov 03 2021 03:56 AM
Rmcea Offline OP
Hello
I have just replaced the oil line to the rocker oiler on my 216 engine. My question is regarding the rocker oiler on the rocker shaft. How much rotation is normal of the oiler on the rocker shaft. Mine has about 180 degrees of rotation with the oil line disconnected. I see that there is a pin the goes through the rocker shaft and the oiler and am concerned the pin may be Brocken.
I have attached a picture of the oiler. Any help or advice would be appreciated
Thank you
Rmcea #1429053 Wed Nov 03 2021 02:16 PM
Looks OK to me. I am not sue what the pin does, but I suspect it keeps the two rocker shafts separated. Others will correct me if that is not the case
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
My Webshots Album [good-times.webshots.com]
MikeE #1429058 Wed Nov 03 2021 02:33 PM
Rmcea Offline OP
Thank you
Rmcea #1429104 Wed Nov 03 2021 09:11 PM
I think the pin is to keep the assembly centered between the shafts.
Without it, if one of the springs was slightly stronger the assembly could be pushed one way, causing the supply tube to possibly wear on the head, causing a leak.
My Blog [chev235guy.blogspot.com]
