The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to The Wayback Machine.
My '51 - 3100 has only one spring on the driver side of the bench seat frame to seat riser. The F.A.M. Sect. 1, Sheet 2.05 shows the spring #3698449 between the seat riser and the seat frame on the driver side but does not show the passenger side. It seems to me there maybe should be a spring in the same location on the passenger side so there would be equal tension on both sides of the seat frame? There is also a hole in the seat riser on the passenger side same as the driver side to maybe accept a spring. So, my question is "should there be a spring on the passenger side or on the driver's side only"?
1939 Packard Standard Eight Coupe 1950 Chevrolet 3100 1956 Cadillac Coupe de Ville 1966 Oldsmobile Toronado 1966 Ford Mustang 1964 Ford Galaxie 500 coupe 1979 Ford F-100 1976 Ford F-150 1995 Ford F-150
