Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
11 members (Gdads51, dougs, Hotrod Lincoln, Djg, 66flea, 51sub), 626 guests, and 4 robots.
The Zone
Forums65
Topics123,421
Posts999,183
Members47,264
Most Online1,229
Jan 21st, 2020
#1428277 Thu Oct 28 2021 06:52 PM
Rmcea Offline OP
I have a 1950 GMC with a 216 engine. The engine has a broken oil line that runs from the block inside the side cover up to the rocker arm. The problem is I cannot get the line out of the larger fitting in the block. I have loosened the line fitting but the line is stuck inside the larger fitting that screws into the block. The larger fitting will unscrew part of the way. I have attached a picture.
Does anyone have any suggestions that would help me
Oil line fitting
Rmcea #1428278 Thu Oct 28 2021 06:56 PM
Ex Hall Monitor
It is attached to the fitting in the block. The whole thing needs to come out. This is from the 38 shop manual but it shows the routing and construction.
Rmcea #1428282 Thu Oct 28 2021 07:52 PM
Curmudgeon
Another poster had a similar problem.
https://www.stovebolt.com/ubbthread...e-216-oil-transfer-tube.html#Post1426544
Many of the classic Chevrolet parts websites sell a repair kit.
