The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (Just Mark, DaveV, buoymaker, Dusty53, jameschevypu50, 68ironhead), 119 guests, and 4 robots.
Forums59
Topics128,597
Posts1,041,768
Members46,055
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
It got to be too much of a hassle, sourcing some parts such as drill guide bushings, and making others. Also, even with a very detailed 2-page instruction sheet, most people didn't have the common sense to use the kit. I finally just gave up.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
Thanks Jerry/Hotrod-Lincoln & Lugnutz - regarding making and showing us Jerry's beautiful tool-set and the excellent photos/installation instructions.
I'd readily buy a set to impress my friends (and, to impress future stovebolters who are working on real "stovebolt six" engines).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
fred c You don't have to use a sledge hammer on your HB,a 3lb. hammer with an oaken 2x2 should do it. Have a helper keep the crank pried forward as you drive it on,or wedge a block of wood back at your pressure plate. I use the 2x2 so it doesn't bruise-up your balancer. As a youth I did bruise some of those,sitting on no. 1 cylinder using a large hammer !!
fred c Offline OP
46 Chevy 1/2 Ton 1929 Model A Phaeton
Thanks for all the info. I have been out of town for a couple of days and I'll be gone again unit the middle of next week. When I get back I'm going to give it a try.
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/36561/filename/Drilling Crankshaft 002.jpg[/img]Great advice. Wish I had known about those jigs when I did mine. Photo of my "frankenjig" attached:
Finally '54
just very confused Nothing wrong with having the HB secured it's just work. Most of them have stayed on just press fit since 37.
Ed Pruss Learned to watch the depth of the hole ,don't want to drill into oil passage in the crank.
fredc not as tough as you think
Page 2 of 2 1 2
