The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (68ironhead, 32vsnake, Gone, cmayna, coilover, 5 Window 9434), 154 guests, and 4 robots.
Forums60
Topics125,015
Posts1,008,932
Members45,121
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Pertronix question
#1423420 Thu Sep 09 2021 02:53 PM
Hello,
I have a 57 235 with the Pertronix kit in the original distributor. Do you need HEI plug wires for this or will stock style work? 12volt original coil.
Re: Pertronix question
Bluetruck21 #1423443 Thu Sep 09 2021 06:50 PM
Sir Searchalot
Any wire except solid core. Some "HEI wire" ends won't fit your cap. Just buy Suppression or spiral wound normal wires.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
I used to think beer was bad for me, so I gave up thinking.
Sometimes no nonsense makes sense, in a sense.
You can't teach a new dog old tricks.
Honk if you're Amish
Bluetruck21 #1423487 Fri Sep 10 2021 01:19 AM
Make sure that your AAA subscription is current before you go very far, and make sure to never leave the ignition on without the engine running or your unit will fry and your coil will melt.
I had a faulty ignition switch which remained on once the key was removed. I am lucky that my truck did not burn to the ground overnight.
Bluetruck21 #1423531 Fri Sep 10 2021 01:03 PM
Thanks for the info!
bartamos #1426756 Wed Oct 13 2021 02:16 PM
I guess I forgot to say I am trying to get my truck running good again after sitting in my garage for 6 years. I have owned it for 20+ years and have had the Pertronix in it for over 15+ years. I am chasing gremlins which is the reason for the questions (electronic ignition kit, plug wires, current condensers available, carb rebuilding, etc). FYI the current Napa/Echlin inventory at my local Napa is made in Mexico.
Bluetruck21 #1426764 Wed Oct 13 2021 03:07 PM
Moderator - The Electrical Bay and Rocky Mountain Bolters
Please stay on topic and keep it civil.
Another quality post.
Real Trucks Rattle
Bluetruck21 #1426766 Wed Oct 13 2021 03:39 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
If I remember correctly Pertronix instructions say do not use metal core plug wires.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Moderated by  Rusty Rod
