The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Celebrations!!!
HAPPY
BIRTHDAY
C A N A D A
July 1
Over 2022 Bolters live "up over" ... a cool addition to the flavor of
The Stovebolt Page.
Birthday salutes here!
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (kades51, 55shaker, JW51, fixite7, 2 invisible), 106 guests, and 4 robots.
Forums59
Topics128,033
Posts1,036,692
Members45,918
Most Online1,229
Jan 21st, 2020
#1426680 Tue Oct 12 2021 09:36 PM
Goach2 Offline OP
Hi, interested to see any pics of how a dump bed works on a 3600. Have a line on a local bed off a later 1 ton and curious to see what would be needed to make it work. Thanks!
1948 Chevrolet Thriftmaster 3/4 Ton
There are only 10 types of people in this world, those who can read binary and those who can't.
Goach2 #1426742 Wed Oct 13 2021 12:36 PM
Unrepentant VW Lover
Hi Goach!
Is the bed off the 1-ton already a hoist/lift bed? Hydraulic with a PTO-driven pump and cylinder? (if so, does your truck have an SM420 transmission or the 3-speed?) Or a newer electric system? And how much "later" is the 1-ton? Is the 1-ton a dually? If the frames are same width, etc, you might be able to just remove from the one-ton and bolt to the 3/4-ton. A tape measure is your best friend here.
You may already know this ... but ... Just be aware that it will be really, REALLY easy to dangerously overload your 3/4-ton with that bed. The hoist mechanism, if original to the 1-ton, is going to add weight. The bed will add more weight. And then whatever is left over (subtracted from your truck's rated Max Gross Weight) will be available to you for payload ... which won't be a lot. So do the math and see if it is even going to be worth it.
Just food for thought....
smile
I
Cisgendered heteronormative aggressor perpetrating problematic toxic ideas of Chevrolet normativity smile
'49 Chevrolet 3804
Goach2 #1426754 Wed Oct 13 2021 02:13 PM
Mixed Up
What John said!
I'll see if I can get some pictures of our 57 one ton Dually with the dump bed today.
Rain is moving in so we'll see what happens.
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Goach2 #1426757 Wed Oct 13 2021 02:17 PM
Goach2 Offline OP
Thanks John. The donor frame sits between the rails and won't work with the curve of the 3/4 ton frame. I just wanted to see some examples of how it should be assembled on a 3600. I do have the SM420 and am about to pull it to go through it, so I thought it might be a timely upgrade. Although I do occasionally use the truck to haul stuff, I'm not intending on using it for dumping large loads, it would be more for show at events.
Any one with good pics of what this setup should look like? Thanks!
Goach2 #1426768 Wed Oct 13 2021 04:01 PM
Mixed Up
Got a few pictures today before the rain.
The 57 one ton dump and the 48 3/4 ton flatbed.
The one ton has flat frame rails and the 3/4 ton has curved frame rails.
They were built this way for a reason.
"The Flag Pole"
'50 2-ton flatbed
Goach2 #1426769 Wed Oct 13 2021 04:03 PM
Mixed Up
Well the pictures did not turn out very good and why is that dog in there?
Don
"The Flag Pole"
'50 2-ton flatbed
Goach2 #1426775 Wed Oct 13 2021 05:16 PM
Goach2 Offline OP
Thanks Don - I see they 'flattened' out the hump in the rails, but I don't see any lift installed in it. Are you suggesting that you 'flatten' then mount lift the same as 1 ton?
Goach2 #1426776 Wed Oct 13 2021 05:47 PM
Mixed Up
No Goach.
The 48 3/4 ton does not have a hoist on it.
Just showing you the difference between a one ton and a 3/4 ton frame.
John has a one ton single wheel 49. No hoist.
Maybe he can help with your decision. But, a 3/4 ton single tire will be over loaded with just the hoist and steel bed alone.
Frame is not designed to carry that weight.
Hope this helps!
Don
"The Flag Pole"
'50 2-ton flatbed
Goach2 #1426778 Wed Oct 13 2021 07:35 PM
Goach2 Offline OP
Ah, ok thanks Don. Something to consider for sure. Maybe I can find another use for a PTO...
