The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (51sub, Goach2, Hotrod Lincoln, DennisM, D B Cooper, 1 invisible), 102 guests, and 3 robots.
Forums60
Topics126,046
Posts1,018,695
Members45,413
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 62 235 oil bath air cleaner wanted
Hambone #1426470 Sun Oct 10 2021 10:49 PM
Curmudgeon
As you can see in the bulletin, 1960 GM trucks changed to the low profile design Rochester "B" carburetor.
The throat changed to 2-5/8".
It has a bridge on top of the carburetor, that is threaded in the center for the threaded rod (both ends), that holds the air cleaner to the carburetor.
Before 1960, the throat was ~ 2-1/4". The truck air cleaner had a clamp to hold it to the carburetor.
So, from 1960 to 1962 the truck air cleaner construction was different than previous years.
I found this link:
http://67-72chevytrucks.com/vboard/showthread.php?t=656098
Page down on the posting to find the 2 pictures of the black air cleaner. My guess is that this is the original for the 60-62 years.
I expect it would be hard to find.
Beginning 1963, the 6 cylinder engine line-up changed to 230/250/292.
I see GM dealer pictures of a low profile air cleaner (paper filter) with nozzle.
I also see GM dealer pictures of a large oil bath air cleaner that may be an option you could order.
The air cleaner design was probably continued on until the late 60's but I didn't look into it.
These air cleaners would fit the 1960 to 62 truck carburetors.
Hambone #1426720 Wed Oct 13 2021 02:36 AM
Does this photo look like the aircleaner you want?
Came off a big 1961 gmc in Canada
With a pcv valve setup
Let me know
-Stan
Hambone #1426734 Wed Oct 13 2021 11:01 AM
Hambone Offline OP
That is the one that fits the V8 (at least on my 283 truck). I think that will sit up too high. That is bigger then the one I currently have.
HB
1966 Chevrolet K-10
Flappy Fenders
In the Stovebolt Gallery [stovebolt.com]
More pictures on Photobucket [s160.photobucket.com]
1962 Chevrolet C10
1962 Suburban
Hambone #1426750 Wed Oct 13 2021 01:54 PM
Okay, sorry to disappoint
That air cleaner was on top that Rochester next to it on a 261
The big truck has clearance for it, based on the connections it was likely original for that truck up here
If I see a smaller one I’ll let you know
-s
Page 2 of 2 1 2
Moderated by  John Milliman
