The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (59 fleet, FAST55, klhansen, Jethro in Va, 32vsnake, Flatblu4748), 118 guests, and 3 robots.
Forums59
Topics128,581
Posts1,041,644
Members46,050
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1425991 Wed Oct 06 2021 01:48 AM
i need pics on where the wires go. i have looked all over and don't have the right way to install the wires. i tried and made the needle to go on the negative side. so i stopped before something breaks. any help will be nice. p.s. it has three studs two has a fuse between them and the other is to the right
robert b #1425992 Wed Oct 06 2021 01:54 AM
Nobody will be able to help unless you tell us what you’re working on. Year, model, stock or not??
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
robert b #1426025 Wed Oct 06 2021 12:36 PM
sorry 1937 gmc truck with 1998 4.3l engine
robert b #1426036 Wed Oct 06 2021 02:35 PM
Is the amp gauge from 1937 or 1998?
Probably the earlier.
robert b #1426098 Thu Oct 07 2021 01:00 AM
it's rebuilt to fit the 1937
robert b #1426456 Sun Oct 10 2021 08:40 PM
if you still need help I can take a picture of mine (1936) gmc converted to work with a late style GM motor
1936 GMC T-14 restro-mod
robert b #1426481 Mon Oct 11 2021 12:44 AM
yes please
robert b #1428581 Sun Oct 31 2021 01:05 AM
fast55 will you post the pics on the amp gauge. thanks
robert b #1428710 Mon Nov 01 2021 01:58 AM
If the amp gauge reads neg. when you turn on the headlights with engine off, it is correct, if it reads pos., it is just backwards, switch terminals. The amp. gauge he just reads which way the current is flowing, and how much, roughly.
Volt gauge just reads how much!
Ed
robert b #1428730 Mon Nov 01 2021 12:03 PM
You may want the amp gauge for decoration if using an alternator. The amp gauge may not handle the amperage that the alternator can put out.
There is a way to make a shunt so that a small amount of the current goes through the gauge, and it has been a long time since I did that. But I've seen amp gauges fail when a generator was replaced with a high amp alternator
Page 1 of 2 1 2
Moderated by  Rusty Rod
